NAME | Description | Attributes | See Also
Syntax |
integer |
Default value |
1024 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the maximum number of connections that can be made to an LDAP data source to perform read operations.
This property takes an integer.
The value of this property must be at least 1.
This property can also take the following values:
This value means no limit is set for this property.
This property is used to configure the following features:
The common name of the LDAP data source
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
