NAME | Description | Attributes | See Also
Syntax |
string |
Default value |
USER |
Must be set |
No |
Is modifiable |
No |
Is multivalued |
No |
Requires restart |
No |
This property specifies the syslog message category that alert messages should use.
This property is used to configure the following features:
The global configuration of Directory Proxy Server contains properties that affect the overall operation of Directory Proxy Server.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
