Name | Synopsis | Description | Parameters | Return Values | Errors | Files | Attributes | See Also
cc [flags…] -I /usr/cluster/include file -L /usr/cluster/lib -l dsdev
#include <rgm/libdsdev.h>
scha_err_t scds_pmf_stop_monitoring(scds_handle_t handle,
scds_pmf_type_t program_type,
int instance);
The scds_pmf_stop_monitoring() function stops the monitoring of a process tree that is running under PMF control. PMF does not send a signal to stop the process. Rather, PMF makes no future attempts to restart the process.
If the requested process is not under PMF control, scds_pmf_stop_monitoring() returns, with value SCHA_ERR_NOERR.
The following parameters are supported:
The handle returned from scds_initialize(3HA)
Type of program to execute. Valid types are:
Data service application
Fault monitor
Other
For resources with multiple instances, this integer, starting at 0, uniquely identifies the instance. For single instance resources, use 0.
The scds_pmf_stop_monitoring() function returns the following:
The function succeeded.
The function failed.
See scha_calls(3HA) for a description of other error codes.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWscdev |
Interface Stability |
Evolving |
pmfadm(1M), scds_initialize(3HA), scds_pmf_start(3HA), scds_pmf_stop(3HA), scha_calls(3HA), attributes(5)
