The following table summarizes the tasks for installing and configuring Sun Cluster HA for Alliance Gateway and provides cross-references to detailed instructions for performing these tasks. Perform the tasks in the order that they are listed in the table.
Table 2 Tasks for Installing and Configuring Sun Cluster HA for Alliance Gateway
Task |
Instructions |
Plan the Alliance Gateway installation |
Planning the Sun Cluster HA for Alliance Gateway Installation and Configuration |
Install and configure Alliance Gateway | |
Install the Sun Cluster HA for Alliance Gateway packages | |
Register the Sun Cluster HA for Alliance Gateway data service and configure the cluster for the data service |
Registering and Configuring the Sun Cluster HA for Alliance Gateway |
Verify Sun Cluster HA for Alliance Gateway |
Verifying the Sun Cluster HA for Alliance Gateway Installation and Configuration |
Tuning the Sun Cluster HA for Alliance Gateway fault monitor |
Tuning the Sun Cluster HA for Alliance Gateway Fault Monitor |
(Optional) Debug Sun Cluster HA for Alliance Gateway |
