Use this procedure to configure the Sun Cluster HA for Alliance Gateway data service as a failover service.
Become superuser on one of the nodes in the cluster that is the host for Alliance Gateway.
Register the SUNW.gds resource type.
# clresourcetype register SUNW.gds |
Register the SUNW.HAStoragePlus resource type.
# clresourcetype register SUNW.HAStoragePlus |
Create the failover resource group.
# clresourcegroup create [-n node-zone-list] sag-rg |
Specifies a comma-separated, ordered list of zones that can master the resource group. The format of each entry in the list is node. In this format, node specifies the node name and zone specifies the name of a non-global Solaris zone. To specify the global zone, or to specify a node without non-global zones, specify only node. This list is optional. If you omit this list, the global zone of each cluster node can master the resource group.
Create a resource for the Sun Cluster Disk Storage.
# clresource create -g sag-rg \ -t SUNW.HAStoragePlus \ -x FilesystemMountPoints=/swift sag-ds-rs |
Specifies that the resource that you are creating is named sag-ds-rs.
Specifies that the resource is to be added to the Alliance Gateway resource group.
Specifies a list of valid mount points for the file system.
Create a resource for the Sun Cluster logical hostname.
# clreslogicalhost create -g sag-rg \ -h gatewayhostname sag-lh-rs |
Enable the failover resource that contains the Sun Cluster Disk Storage and the Logical hostname resources.
# clresourcegroup online -eM sag-rg |
Create a resource for Alliance Gateway.
Change the variables in the /opt/SUNWscsag/util/sag_config file.
For information about this file, see Configuration Files and Registration Script.
Run the registration script to register the data service and application.
For information about this script, see Configuration Files and Registration Script.
# /opt/SUNWscsag/util/sag_register |
Enable the Alliance Gateway resource.
# clresource enable sag-resource-rs |
Go to Verifying the Sun Cluster HA for Alliance Gateway Installation and Configuration.
