The arbitrary token encapsulates data for the audit trail. It consists of four fixed fields and an array of data. The fixed fields are: a token ID that identifies this token as an arbitrary token, a suggested format field (for example, hexadecimal), a size field that specifies the size of data encapsulated (for example, short), and a count field that gives the number of following items. The remainder of the token is composed of one or more items of the specified type. The arbitrary token appears as follows:
The print format field can take the values shown in Table A-2.
Table A-2 arbitrary Token Print Format Field Values| Value | Action |
| AUP_BINARY | Print date in binary |
| AUP_OCTAL | Print date in octal |
| AUP_DECIMAL | Print date in decimal |
| AUP_HEX | Print date in hex |
| AUP_STRING | Print date as a string |
The item size field can take the values shown in Table A-3.
Table A-3 arbitrary Token Item Size Field Values| Value | Action |
| AUR_BYTE | Data is in units of bytes (1 byte) |
| AUR_SHORT | Data is in units of shorts (2 bytes) |
| AUR_LONG | Data is in units of longs (4 bytes) |
