SunSHIELD Basic Security Module Guide
iport Token
The iport token contains the TCP (or UDP) port address. The token has two fields: a token ID that identifies this as an iport token and the TCP/UDP port address. Figure A-16 shows an iport token.
Figure A-16 iport Token Format
Graphic
