When a user thread issues a write(2) system call, it passes the address of a buffer in user space:
char buffer[] = "python"; count = write(fd, buffer, strlen(buffer) + 1);
The system builds a uio(9S) structure to describe this transfer by allocating an iovec(9S) structure and setting the iov_base field to the address passed to write(2), in this case, buffer. The uio(9S) structure is what is passed to the driver write(9E) routine (see "Vectored I/O " for more information about the uio(9S) structure).
The problem is that this address is in user space, not kernel space, and so is not guaranteed to be currently in memory. It is not even guaranteed to be a valid address. In either case, accessing a user address directly from the device driver or from the kernel could crash the system, so device drivers should never access user addresses directly. Instead, they should always use one of the data transfer routines in the Solaris 7 DDI/DKI that transfer data into or out of the kernel; see "Copying Data" and "uio(9S) Handling" for a summary of the available routines. These routines are able to handle page faults, either by bringing the proper user page in and continuing the copy transparently, or by returning an error on an invalid access.
Two routines commonly used are copyout(9F) to copy data from kernel space to user space and copyin(9F) to copy data from user space to kernel space. ddi_copyout(9F) and ddi_copyin(9F) operate similarly but are to be used in the ioctl(9E) routine. copyin(9F) and copyout(9F) can be used on the buffer described by each iovec(9S) structure, or uiomove(9F) can perform the entire transfer to or from a contiguous area of driver (or device) memory.
