This is the general syntax of conditional breakpoints:
address,count:b command
In this example, address is the address at which to set the breakpoint. count is the number of times the breakpoint should be ignored (note that 0 means break only when the command returns zero). command is the adb(1) command to execute.
Breakpoints can also be set to occur only if a certain condition is met. By providing a command, the breakpoint will be taken only if the count is reached or the command returns zero. For example, a breakpoint that occurs only on certain I/O controls could be set in the driver's ioctl(9E) routine. Here is an example of breaking only in the sdioctl() routine if the DKIOGVTOC (get volume table of contents) I/O control occurs.
kadb[0]: sdioctl+4,0:b <i1-0x40Bkadb[0]: $bbreakpoints count bkpt command 0 sdioctl+4 <i1-0x40B kadb[0]: :c
Adding four to sdioctl skips to the second instruction in the routine, bypassing the save instruction that establishes the stack. The `<i1' refers to the first input register, which is the second parameter to the routine (the cmd argument of ioctl(9E)). The count of zero is impossible to reach, so it stops only when the command returns zero, which is when `i1 - 0x40B' is true. This means i1 contains 0x40B (the value of the ioctl(9E) command, determined by examining the ioctl definition).
To force the breakpoint to be reached, the prtvtoc(1M) command is used. It is known to issue this I/O control:
# prtvtoc /dev/rdsk/c0t3d0s0breakpoint sdioctl+4: st %i5, [%fp + 0x58] breakpoint sdioctl+4: mov %i0, %o0 kadb[0]: $csdioctl(0x800018,0x40b,0xeffffc04,0x5,0xff34dc68,0xf03f0c00) + 4 ioctl(0xf03f0c90,0xf03f0c00,0x3,0x18,0xff445f5c,0xff7a09e0) + 270 syscall_ap(0x3) + 6c syscall_trap(?) + 150 Syssize(0x3) + 20458 Syssize(0x3,0x22f70,0xeffffc04,0x1,0x4,0xefffff6c) + fc14 Syssize(0xefffff6c,0xffffffff,0x1,0x1,0x3,0x22f70) + f5b4 Syssize(0x2,0xeffffec4,0xeffffed0,0x22c00,0x0,0x1) + ebe4
kadb(1M) cannot always determine where the bottom of the stack is. In the previous example, the call to Syssize is not part of the stack.
