The following device driver entry points are used to manage device context.
int xxdevmap_map(devmap_cookie_t handle, dev_t dev, u_int flags, offset_t offset, size_t len, void **new_devprivate);
This entry point is called after the driver returns from its devmap(9E) entry point and the system has established the user mapping to the device memory. The devmap_map(9E) entry point enables a driver to perform additional processing or to allocate mapping specific private data. For example, in order to support context switching, the driver has to allocate a context structure and associate it with the mapping.
The system expects the driver to return a pointer to the allocated private data in *new_devprivate. The driver must store offset and len, which define the range of the mapping, in its private data. Later, when the system calls devmap_unmap(9E), the driver will use offset and len stored in new_devprivate to check if the entire mapping, or just a part of it, is being unmapped.
flags indicates whether the driver should allocate a private context for the mapping. For example, a driver may allocate a memory region to store the device context if flags is set to MAP_PRIVATE, or it might return a pointer to a shared region if MAP_SHARED is set.
Example 12-2 shows an example of a devmap_map(9E) entry point. The driver allocates a new context structure and saves relevant parameters passed in by the entry point. Then the mapping is assigned a new context by either allocating a new one or attaching it to an already existing shared context. The minimum time interval that the mapping should have access to the device is set to one millisecond.
static int
struct xxstate *xsp = ddi_get_soft_state(statep,
getminor(dev));
struct xxctx *newctx;
/* create a new context structure */
newctx = kmem_alloc(sizeof (struct xxctx), KM_SLEEP);
newctx->xsp = xsp;
newctx->handle = handle;
newctx->offset = offset;
newctx->flags = flags;
newctx->len = len;
mutex_enter(&xsp->ctx_lock);
if (flags & MAP_PRIVATE) {
/* allocate a private context and initialize it */
newctx->context = kmem_alloc(XXCTX_SIZE, KM_SLEEP);
xxctxinit(newctx);
} else {
/* set a pointer to the shared context */
newctx->context = xsp->ctx_shared;
mutex_exit(&xsp->ctx_lock);
/* give at least 1 ms access before context switching */
devmap_set_ctx_timeout(handle, drv_usectohz(1000));
/* return the context strcuture */
*new_devprivate = newctx;
return(0);
int xxdevmap_access(devmap_cookie_t handle, void *devprivate, offset_t offset, size_t len, u_int type, u_int rw);
This entry point is called when an access is made to a mapping whose translations are invalid. Mapping translations are invalidated when the mapping is created with devmap_devmem_setup(9F) in response to mmap(2), duplicated by fork(2), or explicitly invalidated by a call to devmap_unload(9F).
handle is the mapping handle of the mapping that was accessed by a user process.
devprivate is a pointer to the driver private data associated with the mapping.
offset is the offset within the mapping that was accessed.
len is the length in bytes of the memory being accessed.
type is the type of access operation.
rw specifies the direction of access.
The system expects devmap_access(9E) to call either devmap_do_ctxmgt(9F) or devmap_default_access(9F) to load the memory address translations before it returns. For mappings that support context switching, the device driver should call devmap_do_ctxmgt(9F). This routine is passed all parameters from devmap_access(9E), and in addition a pointer to the driver entry point devmap_contextmgt(9E), which handles the context switching. For mappings that do not support context switching, the driver should call devmap_default_access(9F), whose only purpose is to call devmap_load(9F) to load the user translation.
Example 12-3 shows an example of a devmap_access(9E) entry point. The mapping is devided into two regions. The region starting at offset OFF_CTXMG with a length of CTXMGT_SIZE bytes supports context management. The rest of the mapping supports default access.
#define OFF_CTXMG 0
#define CTXMGT_SIZE 0x20000
static int
offset_t off, size_t len, u_int type, u_int rw)
offset_t diff;
int error;
if ((diff = off - OFF_CTXMG) >= 0 && diff < CTXMGT_SIZE) {
error = devmap_do_ctxmgt(handle, devprivate, off, len, type,
rw, xxdevmap_contextmgt);
} else {
error = devmap_default_access(handle, devprivate, off,
len, type, rw);
return (error);
int xxdevmap_contextmgt(devmap_cookie_t handle, void *devprivate, offset_t offset, size_t len, u_int type, u_int rw);
In general, devmap_contextmgt(9E) should call devmap_unload(9F), with the handle of the mapping that currently has access to the device, to invalidate the translations for that mapping. This ensures that a call to devmap_access(9E) occurs for the current mapping the next time it is accessed. To validate the mapping translations for the mapping that caused the access event to occur, the driver must restore the device context for the process requesting access and call devmap_load(9F) on the handle of the mapping that generated the call to this entry point.
Accesses to portions of mappings that have had their mapping translations validated by a call to devmap_load(9F) do not generate a call to devmap_access(9E). A subsequent call to devmap_unload(9F) invalidates the mapping translations and allows devmap_access(9E) to be called again.
If either devmap_load(9F) or devmap_unload(9F) returns an error, devmap_contextmgt(9E) should immediately return that error. If the device driver encounters a hardware failure while restoring a device context, a -1 should be returned. Otherwise, after successfully handling the access request, devmap_contextmgt(9E) should return zero. A return of other than zero from devmap_contextmgt(9E) will cause a SIGBUS or SIGSEGV to be sent to the process.
Example 12-4 shows how to manage a one-page device context.
xxctxsave() and xxctxrestore() are device-dependent context save and restore functions. xxctxsave() reads data from the registers using the Solaris 7 DDI/DKI data access routines and saves it in the soft state structure. xxctxrestore() takes data saved in the soft state structure and writes it to device registers using the Solaris 7 DDI/DKI data access routines.
static int
int error;
struct xxctx *ctxp = devprivate;
struct xxstate *xsp = ctxp->xsp;
/* unload mapping for current context */
if (xsp->current_ctx != NULL) {
if ((error = devmap_unload(xsp->current_ctx->handle,
off, len)) != 0) {
xsp->current_ctx = NULL;
return (error);
/* Switch device context - device dependent */
if (xxctxsave(xsp->current_ctx, off, len) < 0) {
return (-1);
if (xxctxrestore(ctxp, off, len) < 0){
return (-1);
xsp->current_ctx = ctxp;
/* establish mapping for new context and return */
error = devmap_load(handle, off, len, type, rw);
if (error)
return (error);
int xxdevmap_dup(devmap_cookie_t handle, void *devprivate, devmap_cookie_t new_handle, void **new_devprivate);
This entry point is called when a device mapping is duplicated, for example, by a user process calling fork(2). The driver is expected to generate new driver private data for the new mapping.
handle is the mapping handle of the mapping being duplicated.
new_handle is the mapping handle of the mapping that was duplicated.
devprivate is a pointer to the driver private data associated with the mapping being duplicated.
*new_devprivate should be set to point to the new driver private data for the new mapping.
Mappings created with devmap_dup(9E) will, by default, have their mapping translations invalidated. This will force a call to the devmap_access(9E) entry point the first time the mapping is accessed.
Example 12-5 shows a devmap_dup(9E) routine.
static int
/* Create a new context for the duplicated mapping */
newctx->xsp = xsp;
newctx->handle = new_handle;
newctx->offset = ctxp->offset;
newctx->flags = ctxp->flags;
newctx->len = ctxp->len;
if (ctxp->flags & MAP_PRIVATE) {
bcopy(ctxp->context, newctx->context, XXCTX_SIZE);
} else {
return(0);
void xxdevmap_unmap(devmap_cookie_t handle, void *devprivate, offset_t off, size_t len, devmap_cookie_t new_handle1, void **new_devprivate1, devmap_cookie_t new_handle2, void **new_devprivate2);
This entry point is called when a mapping is unmapped. This can be caused by a user process exiting or calling the munmap(2) system call.
handle is the mapping handle of the mapping being freed.
off is the offset within the logical device memory at which the unmapping begins.
len is the length in bytes of the memory being unmapped.
new_handle1 is the handle that the system uses to describe the new region that ends at off - 1. new_handle1 may be NULL.
new_devprivate1 is a pointer to be filled in by the driver with the driver -private mapping data for the new region that ends at off - 1. It is ignored if new_handle1 is NULL.
new_handle2 is the handle that the system uses to describe the new region that begins at off + len. new_handle2 may be NULL.
new_devprivate2 is a pointer to be filled in by the driver with the driver private mapping data for the new region that begins at off + len. It is ignored if new_handle2 is NULL.
The devmap_unmap(9E) routine is expected to free any driver private resources that were allocated when this mapping was created, either by devmap_map(9F) or by devmap_dup(9E). If only a part of the mapping is being unmapped, the driver must allocate a new private data for the remaining mapping before freeing the old private data. There is no need to call devmap_unload(9F) on the handle of the mapping being freed, even if it is the mapping with the valid translations. However, to prevent future problems in devmap_access(9E), the device driver should make sure that its representation of the current mapping is set to "no current mapping".
Example 12-6 shows an example of a devmap_unmap(9E) routine.
static void
* If new_handle1 is not NULL, we are unmapping
* at the end of the mapping.
if (new_handle1 != NULL) {
/* Create a new context structure for the mapping */
newctx->xsp = xsp;
/* allocate memory for the private context and copy it */
} else {
/* point to the shared context */
newctx->handle = new_handle1;
newctx->len = off - ctxp->offset;
*new_devprivate1 = newctx;
* If new_handle2 is not NULL, we are unmapping
* at the beginning of the mapping.
if (new_handle2 != NULL) {
/* Create a new context for the mapping */
newctx->xsp = xsp;
} else {
newctx->handle = new_handle2;
newctx->offset = off + len;
newctx->len = ctxp->len - (off + len - ctxp->off);
*new_devprivate2 = newctx;
if (xsp->current_ctx == ctxp)
kmem_free(ctxp->context, XXCTX_SIZE);
kmem_free(ctxp, sizeof (struct xxctx));
