A DMA engine on an ISA bus in an x86 machine has the following attributes:
It accesses only the first 16 megabytes of memory.
It performs transfers to segments up to 32 Kbytes in size.
It has a 16-bit counter register.
It can handle byte-aligned transfers.
It supports 1-, 2- and 4-byte burst sizes.
It has a minimum effective transfer size of 1 byte.
It can hold up to 17 scatter-gather transfers.
The resulting attribute structure is:
static ddi_dma_attr_t attributes = {
DMA_ATTR_V0, /* Version number */
0x00000000, /* low address */
0x00FFFFFF, /* high address */
0xFFFF, /* counter register max */
1, /* byte alignment */
0x7, /* burst sizes */
0x1, /* minimum transfer size */
0xFFFFFFFF, /* max xfer size */
0x00007FFF, /* address register max */
17, /* no scatter-gather */
512, /* device operates on sectors */
0, /* attr flag: set to 0 */
