This section adds the following fields to the state structure. See "Software State Structure" for more information.
int partial; /* DMA object partially mapped, use windows */ int nwin; /* number of DMA windows for this object */ int windex; /* index of the current active window */
static int
xxstart (caddr_t arg)
struct xxstate *xsp = (struct xxstate *)arg;
struct device_reg *regp = xsp->reg;
ddi_dma_cookie_t cookie;
int status;
mutex_enter(&xsp->mu);
if (xsp->busy) {
/* transfer in progress */
mutex_exit(&xsp->mu);
return (0);
xsp->busy = 1;
if (transfer is a read) {
flags = DDI_DMA_READ;
} else {
flags = DDI_DMA_WRITE;
flags |= DDI_DMA_PARTIAL;
status = ddi_dma_buf_bind_handle(xsp->handle, xsp->bp,
flags, xxstart, (caddr_t)xsp, &cookie, &ccount);
if (status != DDI_DMA_MAPPED &&
status != DDI_DMA_PARTIAL_MAP)
return (0);
if (status == DDI_DMA_PARTIAL_MAP) {
ddi_dma_numwin(xsp->handle, &xsp->nwin);
xsp->partial = 1;
xsp->windex = 0;
} else {
xsp->partial = 0;
program the DMA engine
return (1);
There are two functions operating with DMA windows. The first, ddi_dma_numwin(9F), returns the number of DMA windows for a particular DMA object. The other function, ddi_dma_getwin(9F), allows repositioning (reallocation of system resources) within the object. It shifts the current window to a new window within the object. Because ddi_dma_getwin(9F) reallocates system resources to the new window, the previous window becomes invalid.
It is a severe error to call ddi_dma_getwin(9F) before transfers into the current window are complete.
ddi_dma_getwin(9F) is normally called from an interrupt routine; see Example 7-5. The first DMA transfer is initiated as a result of a call to the driver. Subsequent transfers are started from the interrupt routine.
The interrupt routine examines the status of the device to determine if the device completed the transfer successfully. If not, normal error recovery occurs. If the transfer was successful, the routine must determine if the logical transfer is complete (the entire transfer specified by the buf(9S) structure) or if this was only one DMA window. If it was only one window, it moves the window with ddi_dma_getwin(9F), retrieves a new cookie, and starts another DMA transfer.
If the logical request has been completed, the interrupt routine checks for pending requests and starts a transfer, if necessary. Otherwise, it returns without invoking another DMA transfer. Example 7-5 illustrates the usual flow control.
static u_int
xxintr(caddr_t arg)
uint8_t status, temp;
/* read status */
status = ddi_get8(xsp->access_hdl, &xsp->regp->csr);
if (!(status & INTERRUPTING)) {
return (DDI_INTR_UNCLAIMED);
ddi_put8(xsp->access_hdl,&xsp->regp->csr, CLEAR_INTERRUPT);
/* for store buffers */
temp = ddi_get8(xsp->access_hdl, &xsp->regp->csr);
if (an error occurred during transfer) {
bioerror(xsp->bp, EIO);
xsp->partial = 0;
} else {
xsp->bp->b_resid -= amount transferred;
if (xsp->partial && (++xsp->windex < xsp->nwin)) {
/* device still marked busy to protect state */
(void) ddi_dma_getwin(xsp->handle, xsp->windex,
&offset, &len, &cookie, &ccount);
program the DMA engine with the new cookie(s)
return (DDI_INTR_CLAIMED);
ddi_dma_unbind_handle(xsp->handle);
biodone(xsp->bp);
xsp->busy = 0;
xsp->partial = 0;
if (pending transfers) {
(void) xxstart((caddr_t)xsp);
