Two address spaces are provided: memory address space and I/O address space. Depending on the device, registers may appear in one or both of these address spaces.
Table 2-5 MCA Address Space|
MCA Space Name |
Address Size |
Data Transfer Size |
Physical Address Range |
Main Memory |
32 |
32 |
0x0-0xffffffff |
I/O |
8/16/32 |
0x0-0xfff |
Registers can be mapped in memory address space and used by the driver as normal memory (see "Device Memory Mapping").
Registers in I/O space are accessed through I/O port numbers using separate kernel routines. See "I/O Space Access") for more information.
Hardware configuration files are normally unnecessary for MCA devices. However, on some occasions drivers for MCA devices may need to use hardware configuration files to augment the information provided by the MCA card. See driver.conf(4) and mca(4) for further details.
