In the 64-bit data model, data structures that use long to define the type of arguments might be incorrect if the argument needs to define a 32-bit quantity. For example, some drivers currently use long to define 32-bit fields in a hardware register layout. To make a driver 64-bit safe, update data structures where necessary to use int32_t or uint32_t, defined in <sys/inttypes.h>, instead of long for 32-bit data. This preserves the binary layout of 32-bit data structures.
For example, change:
struct reg {
ulong_t addr;
uint_t count;
to:
struct reg {
uint32_t addr;
uint32_t count;
