The driver should determine if a high-level interrupt handler is required. If a high-level handler is required and the driver is not coded to provide one, the driver must be rewritten to either include a high-level interrupt or fail the attach.
In the following example, a high-level interrupt is required but not provided by the driver. Consequently, the driver fails the attach.
if (ddi_intr_hilevel(dip, 0) != 0) {
return (DDI_FAILURE);
The driver must first obtain the iblock cookie to initialize mutexes used in the driver handler. Only after those mutexes have been initialized can the interrupt handler be added.
i = ddi_get_iblock_cookie(dip, 0, &isp->iblock_cookie};
if (i != DDI_SUCCESS) {
do error recovery
mutex_init(&isp->mutex, "isp_mutex", MUTEX_DRIVER,
(void *)isp->iblock_cookie);
i = ddi_add_intr(dip, 0, &isp->iblock_cookie,
0, isp_intr, (caddr_t)isp);
do error recovery
