The Solaris 7 DDI/DKI does not support detaching an HBA driver, although target driver children of an HBA can detach. For best results, the HBA driver should fail a detach request. It's better to fail the detach than to include code that cannot be tested.
Example 14-3 provides an example of the xx_detach() function.
static int
isp_detach(dev_info_t *dip, ddi_detach_cmd_t cmd)
switch (cmd) {
case DDI_DETACH:
* At present, detaching HBA drivers is not supported
return (DDI_FAILURE);
case DDI_PM_RESUME:
For information, see Chapter 8, Power Management case DDI_RESUME:
For information, see Chapter 8, Power Management default:
