The tran_dmafree(9E) entry point is the HBA driver function that deallocates DMA resources allocated for a scsi_pkt(9S) structure. The tran_dmafree(9E) entry point is called when the target driver calls scsi_dmafree(9F).
tran_dmafree(9E) must free only DMA resources allocated for a scsi_pkt(9S) structure, not the scsi_pkt(9S) itself. Freeing the DMA resources implicitly performs a DMA synchronization.
The scsi_pkt(9S) will be freed in a separate request to tran_destroy_pkt(9E). Because tran_destroy_pkt(9E) must also free DMA resources, it is important that the HBA driver keep accurate note of whether scsi_pkt(9S) structures have DMA resources allocated.
static void isp_scsi_dmafree( struct scsi_address *ap, struct scsi_pkt *pkt) { struct isp_cmd *sp = (struct isp_cmd *)pkt->pkt_ha_private; if (sp->cmd_flags & CFLAG_DMAVALID) { sp->cmd_flags &= ~CFLAG_DMAVALID; (void)ddi_dma_unbind_handle(sp->cmd_dmahandle); ddi_dma_free_handle(&sp->cmd_dmahandle); sp->cmd_dmahandle = NULL; } }
