The tran_abort(9E) entry point for a SCSI HBA driver is called to abort one or all the commands currently in transport for a particular target. This entry point is called when a target driver calls scsi_abort(9E).
The tran_abort(9E) entry point should attempt to abort the command denoted by the pkt parameter. If the pkt parameter is NULL, tran_abort(9E) should attempt to abort all outstanding commands in the transport layer for the particular target or logical unit.
Each command successfully aborted must be marked with pkt_reason CMD_ABORTED and pkt_statistics OR'd with STAT_ABORTED.
The tran_reset(9E) entry point for a SCSI HBA driver is called to reset either the SCSI bus or a particular SCSI target device. This entry point is called when a target driver calls scsi_reset(9F).
The tran_reset(9E) entry point must reset the SCSI bus if level is RESET_ALL. If level is RESET_TARGET, just the particular target or logical unit must be reset.
Active commands affected by the reset must be marked with pkt_reason CMD_RESET, and with pkt_statistics OR'd with either STAT_BUS_RESET or STAT_DEV_RESET, depending on the type of reset.
Commands in the transport layer, but not yet active on the target, must be marked with pkt_reason CMD_RESET, and with pkt_statistics OR'd with either STAT_ABORTED.
The tran_reset_notify(9E) entry point for a SCSI HBA driver is called to request that the HBA driver notify the target driver via callback when a SCSI bus reset occurs.
isp_scsi_reset_notify(
struct scsi_address *ap,
int flag,
void (*callback)(caddr_t),
caddr_t arg)
struct isp *isp;
struct isp_reset_notify_entry *p, *beforep;
int rval = DDI_FAILURE;
isp = (struct isp *)ap->a_hba_tran->tran_hba_private;
mutex_enter(ISP_REQ_MUTEX(isp));
* Try to find an existing entry for this target
p = isp->isp_reset_notify_listf;
beforep = NULL;
while (p) {
if (p->ap == ap)
break;
beforep = p;
p = p->next;
if ((flag & SCSI_RESET_CANCEL) && (p != NULL)) {
if (beforep == NULL) {
isp->isp_reset_notify_listf = p->next;
} else {
beforep->next = p->next;
kmem_free((caddr_t)p, sizeof (struct
isp_reset_notify_entry));
rval = DDI_SUCCESS;
} else if ((flag & SCSI_RESET_NOTIFY) && (p == NULL)) {
p = kmem_zalloc(sizeof (struct isp_reset_notify_entry),
KM_SLEEP);
p->ap = ap;
p->callback = callback;
p->arg = arg;
p->next = isp->isp_reset_notify_listf;
isp->isp_reset_notify_listf = p;
rval = DDI_SUCCESS;
mutex_exit(ISP_REQ_MUTEX(isp));
return (rval);
