Shared objects are indivisible, whole units that have been generated by a previous link-edit of one or more input files. When the link-editor processes a shared object the entire contents of the shared object become a logical part of the resulting output file image. The shared object is not copied physically during the link-edit as its actual inclusion is deferred until process execution. This logical inclusion means that all symbol entries defined in the shared object are made available to the link-editing process.
The shared object's program data sections and most of the link-editing information sections are unused by the link-editor, as these will be interpreted by the runtime linker when the shared object is bound to generate a runable process. However, the occurrence of a shared object is remembered, and information is stored in the output file image to indicate that this object is a dependency and must be made available at runtime.
By default, all shared objects specified as part of a link-edit are recorded as dependencies in the object being built. This recording is made regardless of whether the object being built actually references symbols offered by the shared object. To minimize runtime linking overhead, specify only those dependencies required to resolve symbol references from the object being built as part of the link-edit. Alternatively, the link-editor's -z ignore option can suppress the dependency recording of unused shared objects.
If a shared object has dependencies on other shared objects, these too will be processed. This processing occurs after all command-line input files have been processed. These shared objects will be used to complete the symbol resolution process, however their names will not be recorded as dependencies in the output file image being generated.
Although the position of a shared object on the link-edit command-line has less significance than it does for archive processing, it can have a global effect. Multiple symbols of the same name are allowed to occur between relocatable objects and shared objects, and between multiple shared objects (see "Symbol Resolution" for more details).
The order of shared objects processed by the link-editor is maintained in the dependency information stored in the output file image. As the runtime linker reads this information, it loads the specified shared objects in the same order. Therefore, the link-editor and the runtime linker select the first occurrence of a symbol of a multiply defined series of symbols.
Multiple symbol definitions, and thus the information to describe the interposing of one definition of a symbol for another, are reported in the load map output generated using the -m option.
