Linker and Libraries Guide
Using a Command-Line Option
The -L option can be used to add a new pathname to the library search path. This option affects the search path at the point it is encountered on the command-line. For example, the command
$ cc -o prog main.o -Lpath1 file1.c -lfoo file2.c -Lpath2 -lbar
searches path1 (then /usr/ccs/lib and /usr/lib) to find libfoo, but searches path1 and then path2 (and then /usr/ccs/lib and /usr/lib) to find libbar.
Pathnames defined using the -L option are used only by the link-editor. They are not recorded in the output file image created for use by the runtime linker.
Note -
You must specify -L if you want the link-editor to search for libraries in your current directory. You can use a period (.) to represent the current directory.
The -Y option can be used to change the default directories searched by the link-editor. The argument supplied with this option takes the form of a colon separated list of directories. For example, the command
$ cc -o prog main.c -YP,/opt/COMPILER/lib:/home/me/lib -lfoo
searches for libfoo only in the directories /opt/COMPILER/lib and /home/me/lib. The directories specified using the -Y option can be supplemented by using the -L option.
