The runtime linker looks in only one standard place for dependencies: /usr/lib for 32-bit dependencies, or /usr/lib/sparcv9 for 64-bit SPARCV9 dependencies. Any dependency specified as a simple filename is prefixed with this default directory name and the resulting pathname is used to locate the actual file.
The actual dependencies of any dynamic executable or shared object can be displayed using ldd(1). For example, the file /usr/bin/cat has the following dependencies:
$ ldd /usr/bin/cat
libc.so.1 => /usr/lib/libc.so.1
libdl.so.1 => /usr/lib/libdl.so.1
Here, the file /usr/bin/cat has a dependency, or needs, the files libc.so.1 and libdl.so.1.
The dependencies actually recorded in a file can be inspected by using the dump(1) command to display the file's .dynamic section, and referencing any entries that have a NEEDED tag. For example:
$ dump -Lvp /usr/bin/cat /usr/bin/cat: [INDEX] Tag Value [1] NEEDED libc.so.1 ......... |
Notice that the dependency libdl.so.1, displayed in the previous ldd(1) example, is not recorded in the file /usr/bin/cat. This is because ldd(1) shows the total dependencies of the specified file, and libdl.so.1 is actually a dependency of /usr/lib/libc.so.1.
In the previous dump(1) example, the dependencies are expressed as simple filenames -- in other words there is no `/' in the name. The use of a simple filename requires the runtime linker to build the required pathname from a set of rules. Filenames that contain an embedded `/' will be used as-is.
The simple filename recording is the standard, most flexible mechanism of recording dependencies, and is provided by using the -h option of the link-editor to record a simple name within the dependency (see "Naming Conventions" and "Recording a Shared Object Name" for additional information on this topic).
Frequently, dependencies are distributed in directories other than /usr/lib. If a dynamic executable or shared object needs to locate dependencies in another directory, the runtime linker must explicitly be told to search this directory.
The recommended way to indicate additional search paths to the runtime linker is to record a runpath during the link-edit of the dynamic executable or shared object (see "Directories Searched by the Runtime Linker" for details on recording this information).
Any runpath recording can be displayed using dump(1) and referring to the entry that has the RPATH tag. For example:
$ dump -Lvp prog prog: [INDEX] Tag Value [1] NEEDED libfoo.so.1 [2] NEEDED libc.so.1 [3] RPATH /home/me/lib:/home/you/lib ......... |
Here, prog has a dependency on libfoo.so.1 and requires the runtime linker to search directories /home/me/lib and /home/you/lib before it looks in the default location /usr/lib.
Another way to add to the runtime linker's search path is to set the environment variable LD_LIBRARY_PATH. This environment variable (which is analyzed once at process start-up) can be set to a colon-separated list of directories, and these directories will be searched by the runtime linker before any runpath specification or default directory. 64-bit executables can have an LD_LIBRARY_PATH_64 variable, which overrides any active LD_LIBRARY_PATH setting.
This environment variable is well suited to debugging purposes, such as forcing an application to bind to a local dependency. For example:
$ LD_LIBRARY_PATH=. prog |
Here the file prog from the previous example is bound to libfoo.so.1, found in the present working directory.
Although useful as a temporary mechanism of influencing the runtime linker's search path, the use of this environment variable is strongly discouraged in production software. Any dynamic executables that can reference this environment variable will have their search paths augmented, which can result in an overall degradation in performance. Also, as pointed out in "Using an Environment Variable" and "Directories Searched by the Runtime Linker", this environment variable affects the link-editor.
It is possible to set up an environment so that, for example, a 64-bit executable has a search path that contains a 32-bit library matching the name being looked for, or vice versa. When this occurs, the dynamic linker rejects the mismatched 32-bit library and continues down its search path looking for a valid 64-bit match. If no match is found, you receive a library not found error message. This can be observed in detail by setting the LD_DEBUG environment variable to include files.
$ LD_LIBRARY_PATH=/usr/bin/sparcv9 LD_DEBUG=files /usr/bin/ls ... 00283: file=libc.so.1; needed by /usr/bin/ls 00283: 00283: file=/usr/lib/sparcv9/libc.so.1 rejected: ELF class mismatch: 32-bit/64-bit 00283: 00283: file=/usr/lib/libc.so.1 [ ELF ]; generating link map 00283: dynamic: 0xef631180 base: 0xef580000 size: 0xb8000 00283: entry: 0xef5a1240 phdr: 0xef580034 phnum: 3 00283: lmid: 0x0 00283: 00283: file=/usr/lib/libc.so.1; analyzing [ RTLD_GLOBAL RTLD_LAZY ] ... |
If a dependency cannot be located, ldd(1) indicates that the object cannot be found, and any attempt to execute the application results in an appropriate error message from the runtime linker:
$ ldd prog
libfoo.so.1 => (file not found)
$ prog
ld.so.1: prog: fatal: libfoo.so.1: open failed: No such file or \
directory
