The special handle RTLD_DEFAULT allows an application to test for the existence of another symbol. The symbol search follows the same model as used to relocate the calling object (see "Relocation Processing"). For example, if the application prog contained the following code fragment:
if ((fptr = (int (*)())dlsym(RTLD_DEFAULT, "foo")) != NULL)
(*fptr)();
then foo will be searched for in prog, followed by /usr/lib/libdl.so.1, and then /usr/lib/libc.so.1. If this code fragment was contained in the file B.so.1 from the example shown in Figure 3-2, then the search for foo will continue into B.so.1 and then C.so.1.
This mechanism provides a robust and flexible alternative to the use of undefined weak references, discussed in "Weak Symbols".
