When an object requires a symbol, the runtime linker searches for that symbol based upon the requesting objects' symbol search scope, and the symbol visibility offered by each object within the process. These attributes are applied as defaults to an object at the time it is loaded, as specific modes to dlopen(3X), and in some cases can be recorded within the object at the time it is built.
Typically, an average user becomes familiar with the default symbol search models that are applied to a dynamic executable and its dependencies, and to objects obtained through dlopen(3X). The former is outlined in this section and the latter, which is also able to exploit the various symbol lookup attributes, is discussed in "Symbol Lookup".
A dynamic executable and all the dependencies loaded with it are assigned world search scope, and global symbol visibility (see "Symbol Lookup"). Thus, when the runtime linker looks up a symbol for a dynamic executable or for any of the dependencies loaded with the executable, it does so by searching each object, starting with the dynamic executable, and progressing through each dependency in the same order in which the objects were mapped.
As discussed in previous sections, ldd(1) lists the dependencies of a dynamic executable in the order in which they are mapped. Therefore, if the shared object libbar.so.1 requires the address of symbol foo to complete its relocation, and this shared object is a dependency of the dynamic executable prog:
$ ldd prog
libfoo.so.1 => /home/me/lib/libfoo.so.1
libbar.so.1 => /home/me/lib/libbar.so.1
Then, the runtime linker first looks for foo in the dynamic executable prog, then in the shared object /home/me/lib/libfoo.so.1, and finally in the shared object /home/me/lib/libbar.so.1.
Symbol lookup can be an expensive operation, especially when the size of symbol names increases and the number of dependencies increases. This aspect of performance is discussed in more detail in" Performance Considerations".
The runtime linker's mechanism of searching for a symbol first in the dynamic executable and then in each of the dependencies means that the first occurrence of the required symbol will satisfy the search. Therefore, if more than one instance of the same symbol exists, the first instance will interpose on all others (see also "Shared Object Processing").
