The default assignment of local symbol visibility to the objects obtained by a dlopen(3X) can be promoted to global by augmenting the mode argument with the RTLD_GLOBAL flag. Under this mode, any objects obtained through a dlopen(3X) can be used by any other objects with world symbol search scope to locate symbols.
In addition, any object obtained by dlopen(3X) with the RTLD_GLOBAL flag will also be available for symbol lookup using dlopen(0) (see "Loading Additional Objects").
If a member of a group, having local symbol visibility, is referenced by another group requiring global symbol visibility, the object's visibility will become a concatenation of both local and global. This promotion of attributes will remain, even if the global group reference is later removed.
