If an initial object, obtained from a dlopen(3X), was to dlopen(3X) a secondary object, both objects would be assigned to a unique group. This situation can prevent either object from locating symbols from one another.
In some implementations it is necessary for the initial object to export symbols for the relocation of the secondary object. This requirement can be satisfied by one of two mechanisms:
Making the initial object an explicit dependency of the second object
Use of the RTLD_PARENT mode flag to dlopen(3X) the secondary object
If the initial object is an explicit dependency of the secondary object, it will also be assigned to the secondary objects' group, and thus will be able to provide symbols for the secondary objects' relocation.
However, if many objects can dlopen(3X) the secondary object, and each of these initial objects must export the same symbols to satisfy the secondary objects' relocation, then the secondary object cannot be assigned an explicit dependency. In this case, the dlopen(3X) mode of the secondary object can be augmented with the RTLD_PARENT flag. This flag causes the propagation of the secondary objects' group to the initial object in the same manner as an explicit dependency would do.
There is one small difference between these two techniques. In the case of specifying an explicit dependency, the dependency itself becomes part of the secondary objects' dlopen(3X) dependency tree, and thus becomes available for symbol lookup with dlopen(3X). In the case of obtaining the secondary object with RTLD_PARENT, the initial object does not become available for symbol lookup with dlopen(3X).
In the case where a secondary object is obtained by dlopen(3X) from an initial object with global symbol visibility, the RTLD_PARENT mode is both redundant and harmless. This case commonly occurs when dlopen(3X) is called from an application or from one of the dependencies of the application.
