Additional objects can be added to a running process's address space using dlopen(3X). This function takes a filename and a binding mode as arguments, and returns a handle to the application. This handle can be used to locate symbols for use by the application using dlsym(3X).
If the filename is specified as a simple filename - in other words, there is no `/' in the name, then the runtime linker will use a set of rules to build an appropriate pathname. Filenames that contain a `/' will be used as is.
These search path rules are exactly the same as are used to locate any initial dependencies (see "Directories Searched by the Runtime Linker"). For example, if the file main.c contains the following code fragment:
#include <stdio.h>
#include <dlfcn.h>
main(int argc, char ** argv)
void * handle;
if ((handle = dlopen("foo.so.1", RTLD_LAZY)) == NULL) {
(void) printf("dlopen: %s\n", dlerror());
exit (1);
then to locate the shared object foo.so.1, the runtime linker will use any LD_LIBRARY_PATH definition present at process initialization, followed by any runpath specified during the link-edit of prog, and finally the default location /usr/lib.
If the filename is specified as:
if ((handle = dlopen("./foo.so.1", RTLD_LAZY)) == NULL) {
then the runtime linker will search for the file only in the current working directory of the process.
It is recommended that any shared object specified using dlopen(3X) be referenced by its versioned filename (for more information on versioning, see "Coordination of Versioned Filenames").
If the required object cannot be located, dlopen(3X) will return a NULL handle. In this case dlerror(3X) can be used to display the true reason for the failure. For example:
$ cc -o prog main.c -ldl $ prog dlopen: ld.so.1: prog: fatal: foo.so.1: open failed: No such \ file or directory |
If the object being added by dlopen(3X) has dependencies on other objects, they too will be brought into the process's address space. This process will continue until all the dependencies of the specified object are loaded. This dependency tree is referred to as a group.
If the object specified by dlopen(3X), or any of its dependencies, are already part of the process image, then the objects will not be processed any further; but a valid handle will still be returned to the application. This mechanism prevents the same object from being mapped more than once, and allows an application to obtain a handle to itself. For example, if the previous main.c example contained the following dlopen() call:
if ((handle = dlopen((const char *)0, RTLD_LAZY)) == NULL) {
then the handle returned from dlopen(3X) can be used to locate symbols within the application itself, within any of the dependencies loaded as part of the process's initialization, or within any objects added to the process's address space, using a dlopen(3X) that specified the RTLD_GLOBAL flag.
