The most common relocation error occurs when a symbol cannot be found. This condition results in an appropriate runtime linker error message and the termination of the application. For example:
$ ldd prog libfoo.so.1 => ./libfoo.so.1 libc.so.1 => /usr/lib/libc.so.1 libbar.so.1 => ./libbar.so.1 libdl.so.1 => /usr/lib/libdl.so.1 $ prog ld.so.1: prog: fatal: relocation error: file ./libfoo.so.1: \ symbol bar: referenced symbol not found |
Here the symbol bar, which is referenced in the file libfoo.so.1, cannot be located.
During the link-edit of a dynamic executable, any potential relocation errors of this sort are flagged as fatal undefined symbols (see "Generating an Executable" for examples). This runtime relocation error can occur if the link-edit of main used a different version of the shared object libbar.so.1 that contained a symbol definition for bar, or if the -z nodefs option was used as part of the link-edit.
If a relocation error of this type occurs because a symbol used as a data reference cannot be located, the error condition will occur immediately during process initialization. However, because of the default mode of lazy binding, if a symbol used as a function reference cannot be found, the error condition will occur after the application has gained control.
This latter case can take minutes or months, or might never occur, depending on the execution paths exercised throughout the code. To guard against errors of this kind, the relocation requirements of any dynamic executable or shared object can be validated using ldd(1).
When the -d option is specified with ldd(1), all dependencies will be printed and all data reference relocations will be processed. If a data reference cannot be resolved, a diagnostic message is produced. From the previous example this reveals:
$ ldd -d prog libfoo.so.1 => ./libfoo.so.1 libc.so.1 => /usr/lib/libc.so.1 libbar.so.1 => ./libbar.so.1 libdl.so.1 => /usr/lib/libdl.so.1 symbol not found: bar (./libfoo.so.1) |
When the -r option is specified with ldd(1), all data and function reference relocations will be processed, and if either cannot be resolved, a diagnostic message is produced.
