Linker and Libraries Guide
Allocate Buffers Dynamically
Large data buffers should usually be allocated dynamically rather than being defined using permanent storage. Often this will result in an overall saving in memory, as only those buffers needed by the present invocation of an application will be allocated. Dynamic allocation also provides greater flexibility by allowing the buffer's size to change without affecting compatibility.
