All data reference relocations must be carried out during process initialization before the application gains control, whereas any function reference relocations can be deferred until the first instance of a function being called. By reducing the number of data relocations, the runtime initialization of a process will be reduced.
Initialization relocation costs can also be deferred by converting data relocations into function relocations, for example, by returning data items by a functional interface. This conversion usually results in a perceived performance improvement as the initialization relocation costs are effectively spread throughout the process's lifetime. It is also possible that some of the functional interfaces will never be called by a particular invocation of a process, thus removing their relocation overhead altogether.
The advantage of using a functional interface can be seen in the section, "Copy Relocations". This section examines a special, and somewhat expensive, relocation mechanism employed between dynamic executables and shared objects, and provides an example of how this relocation overhead can be avoided.
