Shared objects are usually built with position-independent code. References to external data items from code of this type employs indirect addressing through a set of tables (see "Position-Independent Code" for more details). These tables are updated at runtime with the real address of the data items, which allows access to the data without the code itself being modified.
Dynamic executables, however, are generally not created from position-independent code. Therefore it would seem that any references to external data they make can only be achieved at runtime by modifying the code that makes the reference. Modifying any text segment is something to be avoided, and so a relocation technique is employed to solve this reference, which is known as a copy relocation.
When the link-editor is used to build a dynamic executable, and a reference to a data item is found to reside in one of the dependent shared objects, space is allocated in the dynamic executable's .bss, equivalent in size to the data item found in the shared object. This space is also assigned the same symbolic name as defined in the shared object. Along with this data allocation, the link-editor generates a special copy relocation record that will instruct the runtime linker to copy the data from the shared object to this allocated space within the dynamic executable.
Because the symbol assigned to this space is global, it will be used to satisfy any references from any shared objects. The effect of this is that the dynamic executable inherits the data item, and any other objects within the process that make reference to this item will be bound to this copy. The original data from which the copy is made effectively becomes unused.
This mechanism is best explained with an example. This example uses an array of system error messages that is maintained within the standard C library. In previous SunOS operating system releases, the interface to this information was provided by two global variables, sys_errlist[], and sys_nerr. The first variable provided the array of error message strings, while the second conveyed the size of the array itself. These variables were commonly used within an application in the following manner:
$ cat foo.c
extern int sys_nerr;
extern char * sys_errlist[];
char *
error(int errnumb)
if ((errnumb < 0) || (errnumb >= sys_nerr))
return (0);
return (sys_errlist[errnumb]);
Here the application is using the function error to provide a focal point to obtain the system error message associated with the number errnumb.
Examining a dynamic executable built using this code shows the implementation of the copy relocation in more detail:
$ cc -o prog main.c foo.c
$ nm -x prog | grep sys_
[36] |0x00020910|0x00000260|OBJT |WEAK |0x0 |16 |sys_errlist
[37] |0x0002090c|0x00000004|OBJT |WEAK |0x0 |16 |sys_nerr
$ dump -hv prog | grep bss
[16] NOBI WA- 0x20908 0x908 0x268 .bss
$ dump -rv prog
**** RELOCATION INFORMATION ****
.rela.bss:
Offset Symndx Type Addend
0x2090c sys_nerr R_SPARC_COPY 0
0x20910 sys_errlist R_SPARC_COPY 0
Here the link-editor has allocated space in the dynamic executable's .bss to receive the data represented by sys_errlist and sys_nerr. These data will be copied from the C library by the runtime linker at process initialization. Thus, each application that uses these data will get a private copy of the data in its own data segment.
There are actually two downsides to this technique. First, each application pays a performance penalty for the overhead of copying the data at runtime. Secondly, the size of the data array sys_errlist has now become part of the C library's interface. If the size of this array were to change, presumably as new error messages are added, any dynamic executables that reference this array have to undergo a new link-edit to be able to access any of the new error messages. Without this new link-edit, the allocated space within the dynamic executable is insufficient to hold the new data.
These drawbacks can be eliminated if the data required by a dynamic executable are provided by a functional interface. The ANSI C function strerror(3C) illustrates this point. This function is implemented such that it will return a pointer to the appropriate error string, based on the error number supplied to it. One implementation of this function might be:
$ cat strerror.c
static const char * sys_errlist[] = {
"Error 0",
"Not owner",
"No such file or directory",
static const int sys_nerr =
sizeof (sys_errlist) / sizeof (char *);
char *
strerror(int errnum)
if ((errnum < 0) || (errnum >= sys_nerr))
return (0);
return ((char *)sys_errlist[errnum]);
The error routine in foo.c can now be simplified to use this functional interface, which in turn will remove any need to perform the original copy relocations at process initialization.
Additionally, because the data are now local to the shared object the data are no longer part of its interface; which allows the shared object the flexibility of changing the data without adversely effecting any dynamic executables that use it. Eliminating data items from a shared object's interface will generally improve performance while making the shared object's interface and code easier to maintain.
Although copy relocations should be avoided, ldd(1), when used with either the -d or -r options, can be used to verify any that exist within a dynamic executable.
For example, if the dynamic executable prog had originally been built against the shared object libfoo.so.1 such that the following two copy relocations had been recorded:
$ nm -x prog | grep _size_ [36] |0x000207d8|0x40|OBJT |GLOB |15 |_size_gets_smaller [39] |0x00020818|0x40|OBJT |GLOB |15 |_size_gets_larger $ dump -rv size | grep _size_ 0x207d8 _size_gets_smaller R_SPARC_COPY 0 0x20818 _size_gets_larger R_SPARC_COPY 0 |
and a new version of this shared object is supplied which contains different data sizes for these symbols:
$ nm -x libfoo.so.1 | grep _size_ [26] |0x00010378|0x10|OBJT |GLOB |8 |_size_gets_smaller [28] |0x00010388|0x80|OBJT |GLOB |8 |_size_gets_larger |
then running ldd(1) against the dynamic executable will reveal:
$ ldd -d prog
libfoo.so.1 => ./libfoo.so.1
copy relocation sizes differ: _size_gets_smaller
(file prog size=40; file ./libfoo.so.1 size=10);
./libfoo.so.1 size used; possible insufficient data copied
copy relocation sizes differ: _size_gets_larger
(file prog size=40; file ./libfoo.so.1 size=80);
./prog size used; possible data truncation
Here ldd(1) informs us that the dynamic executable will copy as much data as the shared object has to offer, but only accepts as much as its allocated space allows.
