Data can be reduced by collapsing multiply-defined data. A program with multiple occurrences of the same error messages can be better off by defining one global datum, and have all other instances reference this. For example:
const char * Errmsg = "prog: error encountered: %d";
foo()
(void) fprintf(stderr, Errmsg, error);
The main candidates for this sort of data reduction are strings. String usage in a shared object can be investigated using strings(1). For example:
$ strings -10 libfoo.so.1 | sort | uniq -c | sort -rn |
will generate a sorted list of the data strings within the file libfoo.so.1. Each entry in the list is prefixed with the number of occurrences of the string.
