Version definitions commonly consist of an association of symbol names to a unique version name. These associations are established within a mapfile and supplied to the final link-edit of an object using the link-editor's -M option (this technique was introduced in the section "Reducing Symbol Scope").
A version definition is established whenever a version name is specified as part of the mapfile directive. In the following example, two source files are combined, together with mapfile directives, to produce an object with a defined public interface:
$ cat foo.c
extern const char * _foo1;
void foo1()
(void) printf(_foo1);
$ cat data.c
const char * _foo1 = "string used by foo1()\n";
$ cat mapfile
SUNW_1.1 { # Release X
global:
foo1;
local:
$ cc -o libfoo.so.1 -M mapfile -G foo.o data.o
$ nm -x libfoo.so.1 | grep "foo.$"
[33] |0x0001058c|0x00000004|OBJT |LOCL |0x0 |17 |_foo1
[35] |0x00000454|0x00000034|FUNC |GLOB |0x0 |9 |foo1
Here, the symbol foo1 is the only global symbol defined to provide the shared object's public interface. The special auto-reduction directive "*" causes the reduction of all other global symbols to have local binding within the object being generated (this directive is introduced in "Defining Additional Symbols"). The associated version name, SUNW_1.1, causes the generation of a version definition. Thus, the shared object's public interface consists of the internal version definition SUNW_1.1, associated with the global symbol foo1.
Whenever a version definition, or the auto-reduction directive, are used to generate an object, a base version definition is also created. This base version is defined using the name of the file itself, and is used to associate any reserved symbols generated by the link-editor (see "Generating the Output Image" for a list of these reserved symbols).
The version definitions contained within an object can be displayed using pvs(1) with the -d option:
$ pvs -d libfoo.so.1
libfoo.so.1;
SUNW_1.1;
Here, the object libfoo.so.1 has an internal version definition named SUNW_1.1, together with a base version definition libfoo.so.1.
The link-editor's -z noversion option allows mapfile directed symbol reduction to be performed but suppresses the creation of version definitions.
Starting with this initial version definition, it is possible for the object to evolve by adding new interfaces and updated functionality. For example, a new function, foo2, together with its supporting data structures, can be added to the object by updating the source files foo.c and data.c:
$ cat foo.c
extern const char * _foo2;
void foo1()
void foo2()
(void) printf(_foo2);
$ cat data.c
const char * _foo2 = "string used by foo2()\n";
A new version definition, SUNW_1.2, can be created to define a new interface representing the symbol foo2. In addition, this new interface can be defined to inherit the original version definition SUNW_1.1.
The creation of this new interface is important as it identifies the evolution of the object and enables users to verify and select the interfaces to which they bind. These concepts are covered in more detail in "Binding to a Version Definition" and in "Specifying a Version Binding".
The following example shows the mapfile directives that create these two interfaces:
$ cat mapfile
global:
foo1;
local:
SUNW_1.2 { # Release X+1
global:
foo2;
} SUNW_1.1;
[33] |0x00010644|0x00000004|OBJT |LOCL |0x0 |17 |_foo1
[34] |0x00010648|0x00000004|OBJT |LOCL |0x0 |17 |_foo2
[36] |0x000004bc|0x00000034|FUNC |GLOB |0x0 |9 |foo1
[37] |0x000004f0|0x00000034|FUNC |GLOB |0x0 |9 |foo2
Here, the symbols foo1 and foo2 are both defined to be part of the shared object's public interface. However, each of these symbols is assigned to a different version definition; foo1 is assigned to SUNW_1.1, and foo2 is assigned to SUNW_1.2.
These version definitions, their inheritance, and their symbol association can be displayed using pvs(1) together with the -d, -v and -s options:
$ pvs -dsv libfoo.so.1
libfoo.so.1:
_end;
_GLOBAL_OFFSET_TABLE_;
_DYNAMIC;
_edata;
_PROCEDURE_LINKAGE_TABLE_;
_etext;
SUNW_1.1:
foo1;
SUNW_1.1;
SUNW_1.2: {SUNW_1.1}:
foo2;
SUNW_1.2
Here, the version definition SUNW_1.2 has a dependency on the version definition SUNW_1.1.
The inheritance of one version definition by another is a useful technique that reduces the version information that will eventually be recorded by any object that binds to a version dependency. Version inheritance is covered in more detail in the section "Binding to a Version Definition".
Any internal version definition will have an associated version definition symbol created. As shown in the previous pvs(1) example, these symbols are displayed when using the -v option.
Internal changes to an object that do not require the introduction of a new interface definition, can be defined by creating a weak version definition. Examples of such changes are bug fixes or performance improvements.
Such a version definition is empty, in that it has no global interface symbols associated with it.
For example, if the data file data.c, used in the previous examples, is updated to provide more detailed string definitions:
$ cat data.c const char * _foo1 = "string used by function foo1()\n"; const char * _foo2 = "string used by function foo2()\n"; |
then a weak version definition can be introduced to identify this change:
$ cat mapfile
global:
foo1;
local:
global:
foo2;
} SUNW_1.1;
SUNW_1.2.1 { } SUNW_1.2; # Release X+2
$ pvs -dv libfoo.so.1
libfoo.so.1;
SUNW_1.1;
SUNW_1.2: {SUNW_1.1};
SUNW_1.2.1 [WEAK]: {SUNW_1.2};
Here, the empty version definition is signified by the weak label. These weak version definitions allow applications to verify the existence of a particular implementation by binding to the version definition associated with that functionality. The section "Binding to a Version Definition" illustrates how these definitions can be used in more detail.
The previous examples have shown how new version definitions added to an object have inherited any existing version definitions. It is also possible to create version definitions that are unique and independent. In the following example, two new files, bar1.c and bar2.c, are added to the object libfoo.so.1. These files contribute two new symbols, bar1 and bar2, respectively:
$ cat bar1.c
extern void foo1();
void bar1()
foo1();
$ cat bar2.c
extern void foo2();
void bar2()
foo2();
These two symbols are intended to define two new public interfaces. Neither of these new interfaces are related to each other; however, each expresses a dependency on the original SUNW_1.2 interface.
The following mapfile definition creates this required association:
$ cat mapfile
global:
foo1;
local:
global:
foo2;
} SUNW_1.1;
SUNW_1.3a { # Release X+3
global:
bar1;
} SUNW_1.2;
SUNW_1.3b { # Release X+3
global:
bar2;
} SUNW_1.2;
Again, the version definitions created in libfoo.so.1 using this mapfile, and their related dependencies, can be inspected using pvs(1):
$ cc -o libfoo.so.1 -M mapfile -G foo.o bar.o data.o
libfoo.so.1;
SUNW_1.1;
SUNW_1.3a: {SUNW_1.2};
SUNW_1.3b: {SUNW_1.2};
The following sections explore how these version definition recordings can be used to verify runtime binding requirements and control the binding requirements of an object during its creation.
