Linker and Libraries Guide
Relocatable Objects
The preceding sections have described how version information can be recorded and used within dynamic objects. Relocatable objects can maintain versioning information in a similar manner; however, there are one or two subtle differences in how this information is used.
Any version definitions supplied to the link-edit of a relocatable object are recorded in exactly the same format as has been described in previous examples. However, by default, symbol reduction is not carried out on the object being created. Instead, when the relocatable object is finally used as input to the generation of a dynamic object, the version recording itself will be used to determine the symbol reductions to apply.
In addition, any version definitions found in relocatable objects will be propagated to the dynamic object. For an example of version processing in relocatable objects, see "Reducing Symbol Scope".
