When the runtime linker binds a dynamic executable with its dependencies, it builds a linked list of link-maps to describe the process. The link-map structure describes each object within the process and is defined in/usr/include/sys/link.h. The symbol search mechanism required to bind objects of an application traverses this list of link-maps. This link-map list is said to provide the name-space for process symbol resolution.
The runtime linker itself is also described by a link-map, and this link-map is maintained on a different list from that of the application objects. This results in the runtime linker residing in its own unique name space, which prevents any direct binding of the application to services within the runtime linker. (An application can only call upon the public services of the runtime linker by the filter libdl.so.1).
The rtld-audit interface employs its own link-map list on which it maintains any audit libraries. This results in the audit libraries being isolated from the symbol binding requirements of the application. Inspection of the application link-map list is possible with dlmopen(3X), which, when used with the RTLD_NOLOAD flag, allows the audit library to query an object's existence without causing its loading.
Two identifiers are defined in /usr/include/link.h to define the application and runtime linker link-map lists:
#define LM_ID_BASE 0 /* application link-map list */ #define LM_ID_LDSO 1 /* runtime linker link-map list */ |
Each rtld-audit support library is assigned a unique free link-map identifier.
