When building an executable file that uses dynamic linking, the link-editor adds a program header element of type PT_INTERP to an executable file, instructing the system to invoke the runtime linker as the program interpreter. exec(2) and the runtime linker cooperate to create the process image for the program, which entails the following actions:
Adding the executable file's memory segments to the process image
Adding shared object memory segments to the process image
Performing relocations for the executable file and its shared objects
Closing the file descriptor that was used to read the executable file, if one was given to the runtime linker
Calling any .init section provided in the objects mapped. See "Initialization and Termination Functions".
Transferring control to the program, making it look as if the program had received control directly from exec(2)
The link-editor also constructs various data that assist the runtime linker for executable and shared object files. As shown above in "Program Header," these data reside in loadable segments, making them available during execution. (Once again, recall the exact segment contents are processor-specific.)
A .dynamic section with type SHT_DYNAMIC holds various data. The structure residing at the beginning of the section holds the addresses of other dynamic linking information.
The .hash section with type SHT_HASH holds a symbol hash table.
The .got and .plt sections with type SHT_PROGBITS hold two separate tables: the global offset table and the procedure linkage table. Sections below explain how the runtime linker uses and changes the tables to create memory images for object files.
As explained in "Program Loading (Processor-Specific)", shared objects can occupy virtual memory addresses that are different from the addresses recorded in the file's program header table. The runtime linker relocates the memory image, updating absolute addresses before the application gains control. Although the absolute address values will be correct if the library is loaded at the addresses specified in the program header table, this normally is not the case.
If the process environment (see exec(2)) contains a variable named LD_BIND_NOW with a non-null value, the runtime linker processes all relocation before transferring control to the program. For example, each of the environment entries:
LD_BIND_NOW=1 LD_BIND_NOW=on LD_BIND_NOW=off |
specifies this behavior. The runtime linker can evaluate procedure linkage table entries lazily, thereby avoiding resolution and relocation overhead for functions that are not called. See "Procedure Linkage Table (Processor-Specific)" for more information.
If an object file participates in dynamic linking, its program header table will have an element of type PT_DYNAMIC. This segment contains the .dynamic section. A special symbol, _DYNAMIC, labels the section, which contains an array of the following structures (defined in sys/link.h):
typedef struct {
Elf32_Sword d_tag;
union {
Elf32_Word d_val;
Elf32_Addr d_ptr;
Elf32_Off d_off;
} d_un;
} Elf32_Dyn;
typedef struct {
Elf64_Xword d_tag;
union {
Elf64_Xword d_val;
Elf64_Addr d_ptr;
} d_un;
} Elf64_Dyn;
For each object with this type, d_tag controls the interpretation of d_un.
These Elf32_Word objects represent integer values with various interpretations.
These Elf32_Addr objects represent program virtual addresses. As mentioned previously, a file's virtual addresses might not match the memory virtual addresses during execution. When interpreting addresses contained in the dynamic structure, the runtime linker computes actual addresses, based on the original file value and the memory base address. For consistency, files do not contain relocation entries to correct addresses in the dynamic structure.
The following table summarizes the tag requirements for executable and shared object files. If a tag is marked mandatory, then the dynamic linking array must have an entry of that type. Likewise, optional means an entry for the tag can appear but is not required.
Table 7-41 Dynamic Array Tags, d_tag|
Name |
Value |
d_un |
Executable |
Shared Object |
DT_NULL |
0 |
Ignored |
Mandatory |
Mandatory |
DT_NEEDED |
1 |
d_val |
Optional |
Optional |
DT_PLTRELSZ |
2 |
d_val |
Optional |
Optional |
DT_PLTGOT |
3 |
d_ptr |
Optional |
Optional |
DT_HASH |
4 |
d_ptr |
Mandatory |
Mandatory |
DT_STRTAB |
5 |
d_ptr |
Mandatory |
Mandatory |
DT_SYMTAB |
6 |
d_ptr |
Mandatory |
Mandatory |
DT_RELA |
7 |
d_ptr |
Mandatory |
Optional |
DT_RELASZ |
8 |
d_val |
Mandatory |
Optional |
DT_RELAENT |
9 |
d_val |
Mandatory |
Optional |
DT_STRSZ |
10 |
d_val |
Mandatory |
Mandatory |
DT_SYMENT |
11 |
d_val |
Mandatory |
Mandatory |
DT_INIT |
12 |
d_ptr |
Optional |
Optional |
DT_FINI |
13 |
d_ptr |
Optional |
Optional |
DT_SONAME |
14 |
d_val |
Ignored |
Optional |
DT_RPATH |
15 |
d_val |
Optional |
Ignored |
DT_SYMBOLIC |
16 |
Ignored |
Ignored |
Optional |
DT_REL |
17 |
d_ptr |
Mandatory |
Optional |
DT_RELSZ |
18 |
d_val |
Mandatory |
Optional |
DT_RELENT |
19 |
d_val |
Mandatory |
Optional |
DT_PLTREL |
20 |
d_val |
Optional |
Optional |
DT_DEBUG |
21 |
d_ptr |
Optional |
Ignored |
DT_TEXTREL |
22 |
Ignored |
Optional |
Optional |
DT_JMPREL |
23 |
d_ptr |
Optional |
Optional |
DT_VALRNGLO |
0x6ffffd00 |
Unspecified |
Unspecified |
Unspecified |
DT_MOVEENT |
0x6ffffdfa |
d_val |
Optional |
Optional |
DT_MOVESZ |
0x6ffffdfb |
d_val |
Optional |
Optional |
DT_FEATURE |
0x6ffffdfc |
d_val |
Optional |
Optional |
DT_POSFLAG_1 |
0x6ffffdfd |
d_val |
Optional |
Optional |
DT_SYMINSZ |
0x6ffffdfe |
d_val |
Optional |
Optional |
DT_SYMINENT |
0x6ffffdff |
d_val |
Optional |
Optional |
DT_VALRNGHI |
0x6ffffdff |
Unspecified |
Unspecified |
Unspecified |
DT_ADDRRNGLO |
0x6ffffe00 |
Unspecified |
Unspecified |
Unspecified |
DT_MOVETAB |
0x6ffffefe |
d_ptr |
Optional |
Optional |
DT_SYMINFO |
0x6ffffeff |
d_ptr |
Optional |
Optional |
DT_ADDRRNGHI |
0x6ffffeff |
Unspecified |
Unspecified |
Unspecified |
DT_RELACOUNT |
0x6ffffff9 |
d_val |
Optional |
Optional |
DT_RELCOUNT |
0x6ffffffa |
d_val |
Optional |
Optional |
DT_FLAGS_1 |
0x6ffffffb |
d_val |
Optional |
Optional |
DT_VERDEF |
0x6ffffffc |
d_ptr |
Optional |
Optional |
DT_VERDEFNUM |
0x6ffffffd |
d_val |
Optional |
Optional |
DT_VERNEED |
0x6ffffffe |
d_ptr |
Optional |
Optional |
DT_VERNEEDNUM |
0x6fffffff |
d_val |
Optional |
Optional |
DT_AUXILIARY |
0x7ffffffd |
d_val |
Unspecified |
Optional |
DT_USED |
0x7ffffffe |
d_val |
Optional |
Optional |
DT_FILTER |
0x7fffffff |
d_val |
Unspecified |
Optional |
DT_LOPROC |
0x70000000 |
Unspecified |
Unspecified |
Unspecified |
DT_SPARC_REGISTER |
0x70000001 |
d_val |
Optional |
Optional |
DT_HIPROC |
0x7fffffff |
Unspecified |
Unspecified |
Unspecified |
An entry with a DT_NULL tag marks the end of the _DYNAMIC array.
This element holds the string table offset of a null-terminated string, giving the name of a needed dependency. The offset is an index into the table recorded in the DT_STRTAB entry. See "Shared Object Dependencies" for more information about these names. The dynamic array can contain multiple entries with this type. These entries' relative order is significant, though their relation to entries of other types is not.
This element holds the total size, in bytes, of the relocation entries associated with the procedure linkage table. If an entry of type DT_JMPREL is present, a DT_PLTRELSZ must accompany it.
This element holds an address associated with the procedure linkage table and/or the global offset table.
This element points to the symbol hash table, described in "Hash Table". This hash table refers to the symbol table indicated by the DT_SYMTAB element.
This element holds the address of the string table, described in the first part of this chapter. Symbol names, dependency names, and other strings required by the runtime linker reside in this table.
This element holds the address of the symbol table, described in the first part of this chapter, with Elf32_Sym entries for the 32-bit class of files.
This element holds the address of a relocation table, described in the first part of this chapter. Entries in the table have explicit addends, such as Elf32_Rela for the 32-bit file class.
An object file can have multiple relocation sections. When building the relocation table for an executable or shared object file, the link-editor catenates those sections to form a single table. Although the sections remain independent in the object file, the runtime linker sees a single table. When the runtime linker creates the process image for an executable file or adds a shared object to the process image, it reads the relocation table and performs the associated actions.
If this element is present, the dynamic structure must also have DT_RELASZ and DT_RELAENT elements. When relocation is mandatory for a file, either DT_RELA or DT_REL can occur (both are permitted but not required).
This element holds the total size, in bytes, of the DT_RELA relocation table.
This element holds the size, in bytes, of the DT_RELA relocation entry.
This element holds the size, in bytes, of the string table.
This element holds the size, in bytes, of a symbol table entry.
This element holds the address of the SHT_SUNW_syminfo section.
This element holds the size, in bytes, of a SHT_SUNW_syminfo table entry.
This element holds the size, in bytes, of a SHT_SUNW_syminfo section.
This element holds the address of the initialization function, discussed in "Initialization and Termination Functions".
This element holds the address of the termination function, discussed in "Initialization and Termination Functions".
This element holds the string table offset of a null-terminated string, giving the name of the shared object. The offset is an index into the table recorded in the DT_STRTAB entry. See "Shared Object Dependencies" for more information about these names.
This element holds the string table offset of a null-terminated search library search path string, discussed in "Shared Objects With Dependencies". The offset is an index into the table recorded in the DT_STRTAB entry.
This element's presence in a shared object library alters the runtime linker's symbol resolution algorithm for references within the library. Instead of starting a symbol search with the executable file, the runtime linker starts from the shared object itself. If the shared object fails to supply the referenced symbol, the runtime linker then searches the executable file and other shared objects as usual.
This element is similar to DT_RELA, except its table has implicit addends, such as Elf32_Rel for the 32-bit file class. If this element is present, the dynamic structure must also have DT_RELSZ and DT_RELENT elements.
This element holds the total size, in bytes, of the DT_REL relocation table.
This element holds the size, in bytes, of the DT_REL relocation entry.
This member specifies the type of relocation entry to which the procedure linkage table refers. The d_val member holds DT_REL or DT_RELA, as appropriate. All relocations in a procedure linkage table must use the same relocation.
This member is used for debugging.
This member's absence signifies that no relocation entry should cause a modification to a non-writable segment, as specified by the segment permissions in the program header table. If this member is present, one or more relocation entries might request modifications to a non-writable segment, and the runtime linker can prepare accordingly.
If present, this entry's d_val member holds various state flags. See Table 7-42.
If present, this entry's d_val member holds various state flags. These flags are to be applied to the immediatly following DT_* entry in the .dynamic section.
If present, this entry's d_ptr member holds the address of relocation entries associated solely with the procedure linkage table. Separating these relocation entries lets the runtime linker ignore them during process initialization, if lazy binding is enabled. If this entry is present, the related entries of types DT_PLTRELSZ and DT_PLTREL must also be present.
Holds the address of the version definition table, described in the first part of this chapter, with Elf32_Verdef entries for the 32-bit class of files. See section "Version Definition Section" for more information. Elements within these entries contain indexes into the table recorded in the DT_STRTAB entry.
This element specifies the number of entries in the version definition table.
Holds the address of the version dependency table, described in the first part of this chapter, with Elf32_Verneed entries for the 32-bit class of files. See section "Version Dependency Section" for more information. Elements within these entries contain indexes into the table recorded in the DT_STRTAB entry.
This element specifies the number of entries in the version dependency table.
All Elf32_Rela R_*_RELATIVE relocations have been placed into a single block and this entry specifies the number of entries in that block. This permits ld.so.1 to streamline the processing of RELATIVE relocations.
All Elf32_Rel R_*_RELATIVE relocations have been placed into a single block and this entry specifies the number of entries in that block. This permits ld.so.1 to streamline the processing of RELATIVE relocations.
Holds the string table offset of a null-terminated string that names an object. The offset is an index into the table recorded in the DT_STRTAB entry. Symbols in the auxiliary object will be used in preference to the symbols within this object.
Holds the string table offset of a null-terminated string that names an object. The offset is an index into the table recorded in the DT_STRTAB entry. The symbol table of this object acts as a filter for the symbol table of the named object.
This element holds the total size of the section defined by SHT_SUNW_move. See "Move Section".
This element holds the size, in bytes, of the DT_MOVETAB move entry.
This element holds the address of a move table, described in the first part of this chapter. Entries in the table have Elf32_Move entries for the 32-bit class of files.
If present, this entry's d_val member holds various feature flags defined by DTF_1_*. The feature values are used by the check_rtld_feature() function called by application at runtime to check if the features needed are supported or not.
Values in this inclusive range use the Dyn.d_un.d_val field of the Dynamic structure.
Values in this inclusive range use the Dyn.d_un.d_ptr field of the Dynamic structure. If any adjustment is made to the ELF object after it has been built these entries will need to be adjusted.
This element contains the index of an STT_SPARC_REGISTER symbol. There is one of these entries for every STT_SPARC_REGISTER symbol table entry in the symbol table.
Values in this inclusive range are reserved for processor-specific semantics.
The following dynamic state flags are presently available:
Table 7-42 Dynamic Tags, DT_FLAGS_1|
Name |
Value |
Meaning |
DF_1_NOW |
0x1 |
Perform complete relocation processing |
DT_1_GLOBAL |
0x2 |
Unused |
DT_1_GROUP |
0x4 |
Indicate object is a member of a group |
DT_1_NODELETE |
0x8 |
Object cannot be deleted from a process |
DT_1_LOADFLTR |
0x10 |
Ensure immediate loading of filtee(s) |
DT_1_INITFIRST |
0x20 |
Run objects' initialization first |
DT_1_NOOPEN |
0x40 |
Object can not be used with dlopen(3X) |
DT_1_DIRECT |
0x100 |
Direct bindings enabled |
DT_1_INTERPOSE |
0x400 |
Object is an interposer |
When the object is loaded, all relocation processing is completed; see "When Relocations Are Performed". This state is recorded in the object using the link-editors' -z now option.
Indicates that the object is a member of a group; see "Symbol Lookup". This state is recorded in the object using the link-editors' -B group option.
Indicates that the object cannot be deleted from a process. Thus, if the object is loaded in a process, either directly or as a dependency, with dlopen(3X), it cannot be unloaded with dlclose(3X). This state is recorded in the object using the link-editors' -z nodelete option.
This state is only meaningful for filters (see "Shared Objects as Filters"). When the filter is loaded, all associated filtees are immediately processe; see "Filtee Processing". This state is recorded in the object using the link-editors' -z loadfltr option.
When the object is loaded, its initialization section is run before any other objects loaded with it; see "Initialization and Termination Routines". This specialized state is intended for libthread.so.1. This state is recorded in the object using the link-editors' -z initfirst option.
Indicates that the object cannot be added to a running process with dlopen(3X). This state is recorded in the object using the link-editors' -z nodlopen option.
Object has direct bindings information. This state is recorded in the object using the link-editors' -B direct option
The objects symbol table is to interpose before all symbols but the primary executable. This is enabled with the link-editors' -z interpose option.
Name |
Value |
Meaning |
DF_P1_LAZYLOAD |
0x1 |
The following object is to be lazily loaded |
DT_P1_GROUPPERM |
0x2 |
The following object is to be loaded with groupperms |
The following DT_* entry identifies an object to be loaded. The loading of this object is to be delayed until a symbol binding identified by a Syminfo table entry specifically references this object.
The following DT_* entry identifies an object to be loaded. The symbols in this object are not available for general symbol resolution, instead they are only available to the object(s) which caused it to be loaded.
The following dynamic feature flags are presently available:
Table 7-44 Dynamic Feature Flags, DT_FEATURE|
Name |
Value |
Meaning |
DTF_1_PARINIT |
0x1 |
The partially initialization feature is required. |
Except for the DT_NULL element at the end of the dynamic array and the relative order of DT_NEEDED and DT_POSFLAG_1 elements, entries can appear in any order. Tag values not appearing in the table are reserved.
When the runtime linker creates the memory segments for an object file, the dependencies (recorded in DT_NEEDED entries of the dynamic structure) tell what shared objects are needed to supply the program's services. By repeatedly connecting referenced shared objects and their dependencies, the runtime linker builds a complete process image.
When resolving symbolic references, the runtime linker examines the symbol tables with a breadth-first search. That is, it first looks at the symbol table of the executable program itself, then at the symbol tables of the DT_NEEDED entries (in order), then at the second level DT_NEEDED entries, and so on.
Even when a shared object is referenced multiple times in the dependency list, the runtime linker will connect the object only once to the process.
Names in the dependency list are copies either of the DT_SONAME strings or the path names of the shared objects used to build the object file.
Position-independent code cannot, in general, contain absolute virtual addresses. Global offset tables hold absolute addresses in private data, thus making the addresses available without compromising the position-independence and shareability of a program's text. A program references its global offset table using position-independent addressing and extracts absolute values, thus redirecting position-independent references to absolute locations.
Initially, the global offset table holds information as required by its relocation entries (see "Relocation" for more information). After the system creates memory segments for a loadable object file, the runtime linker processes the relocation entries, some of which will be type R_SPARC_GLOB_DAT (for SPARC), or R_386_GLOB_DAT (for x86), referring to the global offset table.
The runtime linker determines the associated symbol values, calculates their absolute addresses, and sets the appropriate memory table entries to the proper values. Although the absolute addresses are unknown when the link-editor builds an object file, the runtime linker knows the addresses of all memory segments and can thus calculate the absolute addresses of the symbols contained therein.
If a program requires direct access to the absolute address of a symbol, that symbol will have a global offset table entry. Because the executable file and shared objects have separate global offset tables, a symbol's address can appear in several tables. The runtime linker processes all the global offset table relocations before giving control to any code in the process image, thus ensuring the absolute addresses are available during execution.
The table's entry zero is reserved to hold the address of the dynamic structure, referenced with the symbol _DYNAMIC. This allows a program, such as the runtime linker, to find its own dynamic structure without having yet processed its relocation entries. This is especially important for the runtime linker, because it must initialize itself without relying on other programs to relocate its memory image.
The system can choose different memory segment addresses for the same shared object in different programs; it can even choose different library addresses for different executions of the same program. Nonetheless, memory segments do not change addresses once the process image is established. As long as a process exists, its memory segments reside at fixed virtual addresses.
A global offset table's format and interpretation are processor-specific. For SPARC and x86 processors, the symbol _GLOBAL_OFFSET_TABLE_ can be used to access the table. For 64-bit code, the symbol type is an array of Elf64_Addr.
extern Elf32_Addr _GLOBAL_OFFSET_TABLE_[]; |
The symbol _GLOBAL_OFFSET_TABLE_ can reside in the middle of the .got section, allowing both negative and nonnegative subscripts into the array of addresses.
As the global offset table converts position-independent address calculations to absolute locations, the procedure linkage table converts position-independent function calls to absolute locations. The link-editor cannot resolve execution transfers (such as function calls) from one executable or shared object to another. So, the link-editor puts the program transfer control to entries in the procedure linkage table.
On SPARC architectures, procedure linkage tables reside in private data. The runtime linker determines the destinations' absolute addresses and modifies the procedure linkage table's memory image accordingly. The runtime linker thus redirects the entries without compromising the position-independence and shareability of the program's text. Executable files and shared object files have separate procedure linkage tables.
The first four procedure linkage table entries are reserved. (The original contents of these entries are unspecified, despite the example below.) Each entry in the table occupies 3 words (12 bytes), and the last table entry is followed by a nop instruction. For 64-bit SPARCV9 objects, each entry occupies 8 instructions (32 bytes) and must be aligned on a 32-byte boundary (the table as a whole must be aligned on a 256-byte boundary).
A relocation table is associated with the procedure linkage table. The DT_JMP_REL entry in the _DYNAMIC array gives the location of the first relocation entry. The relocation table has one entry, in the same sequence, for each procedure linkage table entry. Except the first four entries, the relocation type is R_SPARC_JMP_SLOT, the relocation offset specifies the address of the first byte of the associated procedure linkage table entry, and the symbol table index refers to the appropriate symbol.
To illustrate procedure linkage tables, the figure below shows four entries: two of the four initial reserved entries, the third is a call to name1, and the fourth is a call to name2. The example assumes the entry for name2 is the table's last entry and shows the following nop instruction. The left column shows the instructions from the object file before dynamic linking. The right column demonstrates a possible way the runtime linker might fix the procedure linkage table entries.
Table 7-45 SPARC: Procedure Linkage Table Example| Object File | Memory Segment |
.PLT0:
unimp
unimp
unimp
.PLT1:
unimp
unimp
unimp
.PLT0: save %sp,-64,%sp call runtime-linker nop .PLT1: .word identification unimp unimp ... |
.PLT101:
sethi (.-.PLT0),%g1
ba,a .PLT0
nop
.PLT102:
sethi (.-.PLT0),%g1
ba,a .PLT0
nop
... .PLT101: sethi (.-.PLT0),%g1 sethi %hi(name1),%g1 jmp1 %g1+%lo(name1),%g0 .PLT102: sethi (.-.PLT0),%g1 sethi %hi(name2),%g1 jmp1 %g1+%lo(name2),%g0 |
nop |
nop |
Following the steps below, the runtime linker and program jointly resolve the symbolic references through the procedure linkage table. Again, the steps described below are for explanation only. The precise execution-time behavior of the runtime linker is not specified.
When first creating the memory image of the program, the runtime linker changes the initial procedure linkage table entries, making them transfer control to one of the runtime linker's own routines. It also stores a word of identification information in the second entry. When it receives control, it can examine this word to find what object called it.
All other procedure linkage table entries initially transfer to the first entry, letting the runtime linker gain control at the first execution of each table entry. For example, the program calls name1, which transfers control to the label .PLT101.
The sethi instruction computes the distance between the current and the initial procedure linkage table entries, .PLT101 and .PLT0, respectively. This value occupies the most significant 22 bits of the %g1 register. In this example, &g1 contains 0x12f000, when the runtime linker receives control.
Next, the ba,a instruction jumps to .PLT0, establishing a stack frame and calls the runtime linker.
With the identification value, the runtime linker gets its data structures for the object, including the relocation table.
By shifting the %g1 value and dividing by the size of the procedure linkage table entries, the runtime linker calculates the index of the relocation entry for name1. Relocation entry 101 has type R_SPARC_JMP_SLOT, its offset specifies the address of .PLT101, and its symbol table index refers to name1. Thus, the runtime linker gets the symbol's real value, unwinds the stack, modifies the procedure linkage table entry, and transfers control to the desired destination.
Although the runtime linker does not have to create the instruction sequences under the Memory Segment column, it might. If it did, some points deserve more explanation.
To make the code reentrant, the procedure linkage table's instructions are changed in a particular sequence. If the runtime linker is fixing a function's procedure linkage table entry and a signal arrives, the signal handling code must be able to call the original function with predictable (and correct) results.
The runtime linker changes two words to convert an entry. It updates each word automatically. Reentrancy is achieved by first overwriting the nop with the jmp1 instruction, and then patching the ba,a to be sethi. If a reentrant function call happens between the two word updates, the jmp1 resides in the delay slot of the ba,a instruction, and cancels the delay instruction. So, the runtime linker gains control a second time. Although both invocations of the runtime linker modify the same procedure linkage table entry, their changes do not interfere with each other.
The first sethi instruction of a procedure linkage table entry can fill the delay slot of the previous entry's jmp1 instruction. Although the sethi changes the value of the %g1 register, the previous contents can be safely discarded.
After conversion, the last procedure linkage table entry (.PLT102 above) needs a delay instruction for its jmp1. The required, trailing nop fills this delay slot.
The LD_BIND_NOW environment variable changes dynamic linking behavior. If its value is non-null, the runtime linker processes R_SPARC_JMP_SLOT relocation entries (procedure linkage table entries) before transferring control to the program. If LD_BIND_NOW is null, the runtime linker evaluates linkage table entries on the first execution of each table entry.
On x86 architectures, procedure linkage tables reside in shared text, but they use addresses in the private global offset table. The runtime linker determines the destinations' absolute addresses and modifies the global offset table's memory image accordingly. The runtime linker thus redirects the entries without compromising the position-independence and shareability of the program's text. Executable files and shared object files have separate procedure linkage tables.
Table 7-46 x86: Procedure Linkage Table Example
.PLT0: pushl got_plus_4
jmp *got_plus_8
nop; nop
nop; nop
.PLT1: jmp *name1_in_GOT
pushl $offset
jmp .PLT0@PC
.PLT2: jmp *name2_in_GOT
pushl $offset
jmp .PLT0@PC
.PLT0: pushl 4(%ebx)
jmp *8(%ebx)
nop; nop
nop; nop
.PLT1: jmp *name1@GOT(%ebx)
pushl $offset
jmp .PLT0@PC
.PLT2: jmp *name2@GOT(%ebx)
pushl $offset
jmp .PLT0@PC
Following the steps below, the runtime linker and program cooperate to resolve the symbolic references through the procedure linkage table and the global offset table.
When first creating the memory image of the program, the runtime linker sets the second and third entries in the global offset table to special values. The steps below explain these values.
If the procedure linkage table is position-independent, the address of the global offset table must be in %ebx. Each shared object file in the process image has its own procedure linkage table, and control transfers to a procedure linkage table entry only from within the same object file. So, the calling function must set the global offset table base register before it calls the procedure linkage table entry.
For example, the program calls name1, which transfers control to the label .PLT1.
The first instruction jumps to the address in the global offset table entry for name1. Initially, the global offset table holds the address of the following pushl instruction, not the real address of name1.
So, the program pushes a relocation offset (offset) on the stack. The relocation offset is a 32-bit, nonnegative byte offset into the relocation table. The designated relocation entry has the type R_386_JMP_SLOT, and its offset specifies the global offset table entry used in the previous jmp instruction. The relocation entry also contains a symbol table index, which the runtime linker uses to get the referenced symbol, name1.
After pushing the relocation offset, the program jumps to .PLT0, the first entry in the procedure linkage table. The pushl instruction pushes the value of the second global offset table entry (got_plus_4 or 4(%ebx)) on the stack, giving the runtime linker one word of identifying information. The program then jumps to the address in the third global offset table entry (got_plus_8 or 8(%ebx)), to jump to the runtime linker.
The runtime linker unwinds the stack, checks the designated relocation entry, gets the symbol's value, stores the actual address of name1 in its global offset entry table, and jumps to the destination.
Subsequent executions of the procedure linkage table entry transfer directly to name1, without calling the runtime linker again. This is because the jmp instruction at .PLT1 jumps to name1 instead of falling through to the pushl instruction.
The LD_BIND_NOW environment variable changes dynamic linking behavior. If its value is non-null, the runtime linker processes R_386_JMP_SLOT relocation entries (procedure linkage table entries) before transferring control to the program. If LD_BIND_NOW is null, the runtime linker evaluates linkage table entries on the first execution of each table entry.
