On SPARC, relocation entries describe how to alter the following instruction and data fields (bit numbers appear in the lower box corners):
On x86, relocation entries describe how to alter the following instruction and data fields (bit numbers appear in the lower box corners):
word32 specifies a 32-bit field occupying 4 bytes with an arbitrary byte alignment. These values use the same byte order as other word values in the x86 architecture):
SPARCV9 also includes a 64-bit word field:
Calculations below assume the actions are transforming a relocatable file into either an executable or a shared object file. Conceptually, the link-editor merges one or more relocatable files to form the output. It first decides how to combine and locate the input files, then updates the symbol values, and finally performs the relocation. Relocations applied to executable or shared object files are similar and accomplish the same result. Descriptions below use the following notation:
Means the addend used to compute the value of the relocatable field
Means the base address at which a shared object is loaded into memory during execution. Generally, a shared object file is built with a 0 base virtual address, but the execution address is different. See "Program Header" for more information about the base address
Means the offset into the global offset table at which the address of the relocation entry's symbol resides during execution. See "Global Offset Table (Processor-Specific)" for more information.
means the address of the global offset table. See "Global Offset Table (Processor-Specific)" for more information.
Means the place (section offset or address) of the procedure linkage table entry for a symbol. A procedure linkage table entry redirects a function call to the proper destination. The link-editor builds the initial procedure linkage table, and the runtime linker modifies the entries during execution. See "Procedure Linkage Table (Processor-Specific)" for more information.
Means the place (section offset or address) of the storage unit being relocated (computed using r_offset)
Means the value of the symbol whose index resides in the relocation entry
SPARC relocation entries apply to bytes (byte8), half-words (half16), or words (the others). x86 relocation entries apply to words. In any case, the r_offset value designates the offset or virtual address of the first byte of the affected storage unit. The relocation type specifies which bits to change and how to calculate their values.
SPARC uses only Elf32_Rela relocation entries with explicit addends and SPARCV9 uses Elf64_Rela. Thus the r_addend member serves as the relocation addend. x86 uses only Elf32_Rel relocation entries, the field to be relocated holds the addend. In all cases the addend and the computed result use the same byte order.
Field names in the following table tell whether the relocation type checks for overflow. A calculated relocation value can be larger than the intended field, and a relocation type can verify (V) the value fits or truncate (T) the result. As an example, V-simm13 means that the computed value can not have significant, nonzero bits outside the simm13 field.
Name |
Value |
Field |
Calculation |
R_SPARC_NONE |
0 |
None |
None |
R_SPARC_8 |
1 |
V-byte8 |
S + A |
R_SPARC_16 |
2 |
V-half16 |
S + A |
R_SPARC_32 |
3 |
V-word32 |
S + A |
R_SPARC_DISP8 |
4 |
V-byte8 |
S + A - P |
R_SPARC_DISP16 |
5 |
V-half16 |
S + A - P |
R_SPARC_DISP32 |
6 |
V-disp32 |
S + A - P |
R_SPARC_WDISP30 |
7 |
V-disp30 |
(S + A - P) >> 2 |
R_SPARC_WDISP22 |
8 |
V-disp22 |
(S + A - P) >> 2 |
R_SPARC_HI22 |
9 |
T-imm22 |
(S + A) >> 10 |
R_SPARC_22 |
10 |
V-imm22 |
S + A |
R_SPARC_13 |
11 |
V-simm13 |
S + A |
R_SPARC_LO10 |
12 |
T-simm13 |
(S + A) & 0x3ff |
R_SPARC_GOT10 |
13 |
T-simm13 |
G & 0x3ff |
R_SPARC_GOT13 |
14 |
V-simm13 |
G |
R_SPARC_GOT22 |
15 |
T-simm22 |
G >> 10 |
R_SPARC_PC10 |
16 |
T-simm13 |
(S + A - P) & 0x3ff |
R_SPARC_PC22 |
17 |
V-disp22 |
(S + A - P) >> 10 |
R_SPARC_WPLT30 |
18 |
V-disp30 |
(L + A - P) >> 2 |
R_SPARC_COPY |
19 |
None |
None |
R_SPARC_GLOB_DAT |
20 |
V-word32 |
S + A |
R_SPARC_JMP_SLOT |
21 |
None |
See R_SPARC_JMP_SLOT, |
R_SPARC_RELATIVE |
22 |
V-word32 |
B + A |
R_SPARC_UA32 |
23 |
V-word32 |
S + A |
R_SPARC_PLT32 |
24 |
V-word32 |
L + A |
R_SPARC_HIPLT22 |
25 |
T-imm22 |
(L + A) >> 10 |
R_SPARC_LOPLT10 |
26 |
T-simm13 |
(L + A) & 0x3ff |
R_SPARC_PCPLT32 |
27 |
V-word32 |
L + A - P |
R_SPARC_PCPLT22 |
28 |
V-disp22 |
(L + A - P) >> 10 |
R_SPARC_PCPLT10 |
29 |
V-simm13 |
(L + A - P) & 0x3ff |
R_SPARC_10 |
30 |
V-simm10 |
S + A |
R_SPARC_11 |
31 |
V-simm11 |
S + A |
R_SPARC_WDISP16 |
40 |
V-d2/disp14 |
(S + A - P) >> 2 |
R_SPARC_WDISP19 |
41 |
V-disp19 |
(S + A - P) >> 2 |
R_SPARC_7 |
43 |
V-imm7 |
S + A |
R_SPARC_5 |
44 |
V-imm5 |
S + A |
R_SPARC_6 |
45 |
V-imm6 |
S + A |
Some relocation types have semantics beyond simple calculation:
This relocation type resembles R_SPARC_LO10, except that it refers to the address of the symbol's global offset table entry and additionally instructs the link-editor to build a global offset table.
This relocation type resembles R_SPARC_13, except that it refers to the address of the symbol's global offset table entry and additionally instructs the link-editor to build a global offset table.
This relocation type resembles R_SPARC_22, except that it refers to the address of the symbol's global offset table entry and additionally instructs the link-editor to build a global offset table.
This relocation type resembles R_SPARC_WDISP30, except that it refers to the address of the symbol's procedure linkage table entry and additionally instructs the link-editor to build a procedure linkage table.
The link-editor creates this relocation type for dynamic linking. Its offset member refers to a location in a writable segment. The symbol table index specifies a symbol that should exist both in the current object file and in a shared object. During execution, the runtime linker copies data associated with the shared object's symbol to the location specified by the offset. See "Copy Relocations" for more details.
This relocation type resembles R_SPARC_32, except that it sets a global offset table entry to the address of the specified symbol. The special relocation type allows you to determine the correspondence between symbols and global offset table entries.
The link-editor creates this relocation type for dynamic linking. Its offset member gives the location of a procedure linkage table entry. The runtime linker modifies the procedure linkage table entry to transfer control to the designated symbol address.
The link-editor creates this relocation type for dynamic linking. Its offset member gives the location within a shared object that contains a value representing a relative address. The runtime linker computes the corresponding virtual address by adding the virtual address at which the shared object is loaded to the relative address. Relocation entries for this type must specify 0 for the symbol table index.
This relocation type resembles R_SPARC_32, except that it refers to an unaligned word. That is, the word to be relocated must be treated as four separate bytes with arbitrary alignment, not as a word aligned according to the architecture requirements.
Name |
Value |
Field |
Calculation |
R_SPARC_NONE |
0 |
None |
None |
R_SPARC_8 |
1 |
V-byte8 |
S + A |
R_SPARC_16 |
2 |
V-half16 |
S + A |
R_SPARC_32 |
3 |
V-word32 |
S + A |
R_SPARC_DISP8 |
4 |
V-byte8 |
S + A - P |
R_SPARC_DISP16 |
5 |
V-half16 |
S + A - P |
R_SPARC_DISP32 |
6 |
V-disp32 |
S + A - P |
R_SPARC_WDISP30 |
7 |
V-disp30 |
(S + A - P) >> 2 |
R_SPARC_WDISP22 |
8 |
V-disp22 |
(S + A - P) >> 2 |
R_SPARC_HI22 |
9 |
V-imm22 |
(S + A) >> 10 |
R_SPARC_22 |
10 |
V-imm22 |
S + A |
R_SPARC_13 |
11 |
V-simm13 |
S + A |
R_SPARC_LO10 |
12 |
T-simm13 |
(S + A) & 0x3ff |
R_SPARC_GOT10 |
13 |
T-simm13 |
G & 0x3ff |
R_SPARC_GOT13 |
14 |
V-simm13 |
G |
R_SPARC_GOT22 |
15 |
T-simm22 |
G >> 10 |
R_SPARC_PC10 |
16 |
T-simm13 |
R_SPARC_PC22 |
17 |
V-disp22 |
(S + A - P) >> 10 |
R_SPARC_WPLT30 |
18 |
V-disp30 |
(L + A - P) >> 2 |
R_SPARC_COPY |
19 |
None |
None |
R_SPARC_GLOB_DAT |
20 |
V-xword64 |
S + A |
R_SPARC_JMP_SLOT |
21 |
None |
R_SPARC_RELATIVE |
22 |
V-xword64 |
B + A |
R_SPARC_UA32 |
23 |
V-word32 |
S + A |
R_SPARC_PLT32 |
24 |
V-word32 |
L + A |
R_SPARC_HIPLT22 |
25 |
T-imm22 |
(L + A) >> 10 |
R_SPARC_LOPLT10 |
26 |
T-simm13 |
(L + A) & 0x3ff |
R_SPARC_PCPLT32 |
27 |
V-disp32 |
L + A - P |
R_SPARC_PCPLT22 |
28 |
V-disp22 |
(L + A - P) >> 10 |
R_SPARC_PCPLT10 |
29 |
V-simm13 |
R_SPARC_10 |
30 |
V-simm10 |
S + A |
R_SPARC_11 |
31 |
V-simm11 |
S + A |
R_SPARC_64 |
32 |
V-xword64 |
S + A |
R_SPARC_OLO10 |
33 |
V-simm13 |
((S + A) & 0x3ff) + O |
R_SPARC_HH22 |
34 |
V-imm22 |
(S + A) >> 42 |
R_SPARC_HM10 |
35 |
T-simm13 |
((S + A) >> 32) & 0x3ff |
R_SPARC_LM22 |
36 |
T-imm22 |
(S + A) >> 10 |
R_SPARC_PC_HH22 |
37 |
V-imm22 |
(S + A - P) >> 42 |
R_SPARC_PC_HM10 |
38 |
T-simm13 |
((S + A - P) >> 32) & 0x3ff |
R_SPARC_PC_LM22 |
39 |
T-imm22 |
(S + A - P) >> 10 |
R_SPARC_WDISP16 |
40 |
V-d2/disp14 |
(S + A - P) >> 2 |
R_SPARC_WDISP19 |
41 |
V-disp19 |
(S + A - P) >> 2 |
R_SPARC_7 |
43 |
V-imm7 |
(S + A) & 0x7f |
R_SPARC_5 |
44 |
V-imm5 |
(S + A) & 0x1f |
R_SPARC_6 |
45 |
V-imm6 |
(S + A) & 0x3f |
R_SPARC_DISP64 |
46 |
V-xword64 |
S + A - P |
R_SPARC_PLT64 |
47 |
V-xword64 |
L + A |
R_SPARC_HIX22 |
48 |
V-imm22 |
((S + A) ^ 0xffffffffffffffff) >> 10 |
R_SPARC_LOX10 |
49 |
T-simm13 |
((S + A) & 0x3ff) | 0x1c00 |
R_SPARC_H44 |
50 |
V-imm22 |
(S + A) >> 22 |
R_SPARC_M44 |
51 |
T-imm10 |
((S + A) >> 12) & 0x3ff |
R_SPARC_L44 |
52 |
T-imm13 |
(S + A) & 0xfff |
R_SPARC_REGISTER |
53 |
V-xword64 |
S + A |
R_SPARC_UA64 |
54 |
V-xword64 |
S + A |
R_SPARC_UA16 |
55 |
V-half16 |
S + A |
This relocation type resembles R_SPARC_64, except that it sets a global offset table entry to the address of the specified symbol. The special relocation type allows you to determine the correspondence between symbols and global offset table entries.
This relocation type resembles R_SPARC_LO10, except that an extra offset is added to make full use of the 13-bit signed immediate field.
This relocation type is used by the assembler when it sees an instruction of the form "imm22-instruction ... %hh(absolute) ...".
This relocation type is generated by the assembler when it sees an instruction of the form "simm13-instruction ... %hm(absolute) ..."
This relocation type is used by the assembler when it sees an instruction of the form "imm22-instruction ... %lm(absolute) ...". This resembles R_SPARC_HI22, except it truncates rather than validates.
This relocation type is used by the assembler when it sees an instruction of the form "imm22-instruction ... %hh(pc-relative) ...".
This relocation type is generated by the assembler when it sees an instruction of the form "simm13-instruction ... %hm(pc-relative) ...".
This relocation type is used by the assembler when it sees an instruction of the form "imm22-instruction ... %lm(pc-relative) ...". This resembles R_SPARC_PC22, except that it truncates rather than validates.
This relocation type is used by the assembler for 7 bit software trap numbers.
This relocation type is used with R_SPARC_LOX10 for executables that will be confined to the uppermost 4GB of the 64-bit address space. Similar to R_SPARC_HI22, but supplies ones complement of linked value.
Used with R_SPARC_HIX22. Similar to R_SPARC_LO10, but always sets bits 10..12 of the linked value.
This relocation type is used by the assembler when it sees an instruction of the form "imm44-instruction ... %h44(absolute) ..".
This relocation type is generated by the assembler when it sees an instruction of the form "imm44-instruction ... %m44(absolute) ...".
This relocation type is used with the R_SPARC_H44 and R_SPARC_M44 relocation types to generate a 44-bit absolute addressing model. The assembler will generate this type when it sees an instruction of the form "imm44-instruction ... %l44(absolute) ...".
This relocation type is used to initialize a register symbol. Its offset member contains the register number to be initialized. There must be a corresponding register symbol for this register of type SHN_ABS.
Name |
Value |
Field |
Calculation |
R_386_NONE |
0 |
none |
none |
R_386_32 |
1 |
word32 |
S + A |
R_386_PC32 |
2 |
word32 |
S + A - P |
R_386_GOT32 |
3 |
word32 |
G + A |
R_386_PLT32 |
4 |
word32 |
L + A - P |
R_386_COPY |
5 |
none |
none |
R_386_GLOB_DAT |
6 |
word32 |
S |
R_386_JMP_SLOT |
7 |
word32 |
S |
R_386_RELATIVE |
8 |
word32 |
B + A |
R_386_GOTOFF |
9 |
word32 |
S + A - GOT |
R_386_GOTPC |
10 |
word32 |
GOT + A - P |
R_386_32PLT |
11 |
word32 |
L + A |
This relocation type computes the distance from the base of the global offset table to the symbol's global offset table entry. It also instructs the link-editor to build a global offset table.
This relocation type computes the address of the symbol's procedure linkage table entry and instructs the link-editor to build a procedure linkage table.
The link-editor creates this relocation type for dynamic linking. Its offset member refers to a location in a writable segment. The symbol table index specifies a symbol that should exist both in the current object file and in a shared object. During execution, the runtime linker copies data associated with the shared object's symbol to the location specified by the offset. See "Copy Relocations".
This relocation type is used to set a global offset table entry to the address of the specified symbol. The special relocation type lets one determine the correspondence between symbols and global offset table entries.
This relocation type computes the difference between a symbol's value and the address of the global offset table. It also instructs the link-editor to build the global offset table.
This relocation type resembles R_386_PC32, except it uses the address of the global offset table in its calculation. The symbol referenced in this relocation normally is _GLOBAL_OFFSET_TABLE_, which also instructs the link-editor to build the global offset table.
