The SPARC architecture supports register symbols, that is, a symbol that initializes a global register. A symbol table entry for a register symbol contains the following:
Table 7-22 Symbol Table Entry: Register Symbol|
Field |
Meaning |
st_name |
Index into string table of the name of the symbol, or 0 for a scratch register. |
st_value |
Register number. See the ABI manual for integer register assignments. |
st_size |
Unused (0). |
st_info |
Bind is typically STB_GLOBAL, type must be STT_SPARC_REGISTER. |
st_other |
Unused (0). |
st_shndx |
SHN_ABS if this object initializes this register symbol; SHN_UNDEF otherwise. |
Table 7-23 SPARC Register Numbers
Name |
Value |
Meaning |
STO_SPARC_REGISTER_G2 |
0x2 |
%g2 |
STO_SPARC_REGISTER_G3 |
0x3 |
%g3 |
Absence of an entry for a particular global register means that the particular global register is not used at all by the object.
