Size-symbol declarations let you define a new global-absolute symbol that represents the size, in bytes, of the specified segment. This symbol can be referenced in your object files. A size-symbol declaration has the following syntax:
segment_name @ symbol_name; |
symbol_name can be any legal C identifier, although the link-editor does not check the syntax of the symbol_name.
