The KCMS AnswerBook contains manuals relevant for software developers using the KCMS (Kodak Color Management System) application program interface. An abstract of each KCMS AnswerBook document follows.
The KCMS CMM Developer's Guide describes how to create a KCMS color management module (CMM). It provides information on how to use the KCMS foundation library, which is a graphics porting interface (GPI) implemented in C++. These interfaces link the device-independent layer of the KCMS library with the color module and enable the flow of data from the application to the color module. Read this book if you are a driver developer who is writing a color module for color management technology.
The KCMS Calibrator Tool Loadable Interface Guide describes how to create a dynamically loadable device handler module that provides the KCMS Calibrator Tool with color correction data to update ICC format files. The book presents an overview of the interaction between the dynamically loadable module and the KCMS Calibrator Tool.
The KCMS Test Suite User's Guide describes a suite of test scripts and the testing facility the CMM developer can use to ensure that a CMM is KCMS-framework compliant. The book is also a reference for anyone interested in the development and use of the KCMS framework.
