Adding Packages and Patches
You can create a finish script to automatically add packages and patches after Solaris is installed on a system. This will not only save you time, but it can ensure consistency in what packages and patches are installed on various systems at your site. When using the pkgadd(1M) or patchadd(1M) commands in your finish scripts, you should use the -R option to specify /a as the root path.
Example 9-1 provides an example finish script to add packages.
Example 9-1 Adding Packages With a Finish Script
#!/bin/sh
BASE=/a
MNT=/a/mnt
ADMIN_FILE=/a/tmp/admin
mkdir ${MNT}
[Mounts a directory on a server that contains the package to install.] mount -f nfs sherlock:/export/package ${MNT}
[Creates a temporary package administration file, patchadd(1M), to force the pkgadd(1M) command not to perform checks (and prompt for questions) when installing a package. This enables you to maintain a hand-off installation when you are adding packages.] cat >${ADMIN_FILE} <<DONT_ASK
mail=root
instance=overwrite
partial=nocheck
runlevel=nocheck
idepend=nocheck
rdepend=nocheck
space=ask
setuid=nocheck
conflict=nocheck
action=nocheck
basedir=default
DONT_ASK
[Adds the package by using the -a option (specifying the package administration file) and the -R option (specifying the root path).] /usr/sbin/pkgadd -a ${ADMIN_FILE} -d ${MNT} -R ${BASE} SUNWxyz
umount ${MNT}
rmdir ${MNT}
In the past, the chroot(1M) command was used with the pkgadd and patchadd commands in the finish script environment. Although this is not recommended, there may be some packages or patches that will not work with the -R option. In those instances, you must create a fake /etc/mnttab file in the /a root path before using the chroot command. The easiest way to do this is to add the following line to your finish script.
cp /etc/mnttab /a/etc/mnttab
