The following example creates a single disk configuration file, 104_test, on a SPARC-based system with a 104-Mbyte disk.
You would redirect the output of the prtvtoc command to a single disk configuration file named 104_test.
# prtvtoc /dev/rdsk/c0t3d0s2 > 104_test |
The 104_test file would look like this:
* /dev/rdsk/c0t3d0s2 partition map
* Dimensions:
* 512 bytes/sector
* 72 sectors/track
* 14 tracks/cylinder
* 1008 sectors/cylinder
* 2038 cylinders* 2036 accessible cylinders
* Flags:
* 1: unmountable
* 10: read-only
* First Sector Last
* Partition Tag Flags Sector Count Sector Mount Directory
1 2 00 0 164304 164303 /
2 5 00 0 2052288 2052287
3 0 00 164304 823536 987839 /disk2/b298
5 0 00 987840 614880 1602719 /install/298/sparc/work
7 0 00 1602720 449568 2052287 /space
