Disk configuration files enable you to use pfinstall from a single system to test profiles against different disk configurations. Follow this procedure to create single-- and multiple-disk configuration files for an x86-based system:
Locate an x86 based system with a disk that you want to test.
Become root.
Create part of the single disk configuration file by saving the output of the fdisk command to a file:
# fdisk -R -W disk_config -h /dev/rdsk/device_name |
disk_config |
Is the name of a disk configuration file. |
Is the device name of the fdisk layout of the entire disk. device_name must be in the form cwtxdyp0 or cxdyp0. |
Append the output of the prtvtoc command to the disk configuration file:
# prtvtoc /dev/rdsk/device_name >> disk_config |
Is the device name of the system's disk. device_name must be in the form cwtxdys2 or cxdys2. |
disk_config |
Is the name of the disk configuration file. |
If you want to test installing Solaris software on multiple disks, concatenate single disk configuration files together and save the output to a new file
# cat disk_file1 disk_file2 > multi_disk_config |
The new file becomes the multiple-disk configuration file. For example:
# cat 104_disk2 104_disk3 104_disk5 > multi_disk_test |
If you've created a multiple-disk configuration file, and the target numbers in the disk device names are not unique, you must edit this file and make them unique.
For example, if you concatenated two disk configuration files together that each had target numbers of t0, you would have to change the second target number to t2 as shown:
* /dev/rdsk/c0t0d0p0 default fdisk table ... * /dev/rdsk/c0t2d0p0 default fdisk table |
You have completed creating disk configuration files for an x86 based system. To use disk configuration files to test profiles, see "Testing a Profile".
The following example creates a single disk configuration file, 500_test, on an x86-based system with a 500-Mbyte disk.
First, you would save the output of the fdisk command to a file named 500_test:
# fdisk -R -W 500_test -h /dev/rdsk/c0t0d0p0 |
The 500_test file would look like this:
* /dev/rdsk/c0t0d0p0 default fdisk table * Dimensions: * 512 bytes/sector * 94 sectors/track * 15 tracks/cylinder * 1455 cylinders * * HBA Dimensions: * 512 bytes/sector * 94 sectors/track * 15 tracks/cylinder * 1455 cylinders * * systid: * 1: DOSOS12 * 2: PCIXOS * 4: DOSOS16 * 5: EXTDOS * 6: DOSBIG * 86: DOSDATA * 98: OTHEROS * 99: UNIXOS * 130: SUNIXOS * * Id Act Bhead Bsect Bcyl Ehead Esect Ecyl Rsect Numsect 130 128 44 3 0 46 30 1001 1410 2050140 |
Second, you would append the output of the prtvtoc command to the 500_test file:
# prtvtoc /dev/rdsk/c0t0d0s2 >> 500_test |
The 500_test file is now a complete disk configuration file:
* Dimensions:
* 512 bytes/sector
* 94 sectors/track
* 1455 cylinders
* HBA Dimensions:
* 512 bytes/sector
* 94 sectors/track
* 1455 cylinders
* systid:
* 1: DOSOS12
* 2: PCIXOS
* 4: DOSOS16
* 5: EXTDOS
* 6: DOSBIG
* 86: DOSDATA
* 98: OTHEROS
* 99: UNIXOS
* 130: SUNIXOS
* Id Act Bhead Bsect Bcyl Ehead Esec Ecyl Rsect Numsect
* /dev/rdsk/c0t0d0s2 partition map
* Dimensions:
* 512 bytes/sector
* 94 sectors/track
* 1110 sectors/cylinder
* 1454 cylinders
* 1452 accessible cylinders
* Flags:
* 1: unmountable
* 10: read-only
* First Sector Last
* Partition Tag Flags Sector Count Sector Mount Directory
2 5 01 1410 2045910 2047319
7 6 00 4230 2043090 2047319 /space
8 1 01 0 1410 1409
9 9 01 1410 2820 422987
