The following information is important to know about begin scripts:
Be careful that you do not specify something in the script that would prevent the mounting of file systems onto /a during an initial or upgrade installation. If the Solaris installation program cannot mount the file systems onto /a, an error will occur and the installation will fail.
Begin scripts should be owned by root and have permissions equal to 644.
