Syntax Rules |
For Example ... |
Keywords can be listed in any order. |
pointer=MS-S display=ati {size=15-inch} |
Keywords are not case sensitive. |
TIMEZONE=US/Central terminal=PC Console |
Values can optionally be enclosed in single (`) or double quotes ("). |
network_interface='none' |
Only one instance of a keyword is valid; however, if you specify more than one keyword, only the first one will be used. |
network_interface=none network_interface=le0 |
