Solaris Advanced Installation Guide
How the System's Root Disk Is Determined
A system's root disk is the disk on the system that contains the root file system. In a profile, you can use the rootdisk variable in place of a disk name, which the Solaris installation program sets to the system's root disk. Table 8-5 describes how the installation program determines the system's root disk for the installation. This only applies during an initial installation; a system's root disk cannot change during an upgrade.
Table 8-5 How the Installation Program Determines the System's Root Disk (Initial Installation Only)
Stage
Action
1
If the root_device keyword is specified in the profile, the installation program sets rootdisk to the root device.
2
If rootdisk is not set and the boot_device keyword is specified in the profile, the installation program sets rootdisk to the boot device.
3
If rootdisk is not set and a filesys cwtxdysz size / entry is specified in the profile, the installation program sets rootdisk to the disk specified in the entry.
4
If rootdisk is not set and a rootdisk.sn entry is specified in the profile, the installation program searches the system's disks (in kernel probe order) for an existing root file system on the specified slice. If a disk is found, the installation program sets rootdisk to the found disk.
5
If rootdisk is not set and partitioning existing is specified in the profile, the installation program searches the system's disks (in kernel probe order) for an existing root file system. If a root file system is not found or more than one is found, an error occurs. If a root file system is found, the installation program sets rootdisk to the found disk.
6
If rootdisk is not set, the installation program sets rootdisk to the disk where the root file system will be installed.
