Open a new text file (it must be named rules) using the editor of your choice.
You can create a new rules file or edit the sample rules file provided in the JumpStart directory you created.
Add a rule in the rules file for each group of systems you want to install using custom JumpStart.
Refer to the following information as you add rules to the rules file:
A rule within the rules file must have the following syntax:
[!]rule_keyword rule_value [&& [!]rule_keyword rule_value]... begin profile finish |
Is a symbol used before a rule keyword to indicate negation. |
Is a symbol used to indicate an optional expression or field. |
Is a symbol used to indicate the preceding expression may be repeated. |
Is a predefined keyword that describes a general system attribute, such as host name (hostname) or memory size (memsize). It is used with the rule value to match a system with the same attribute to a profile. See Table 8-2 for the list of rule keywords. |
Is a value that provides the specific system attribute for the corresponding rule keyword. See Table 8-2 for the list of rule values. |
Is a symbol that must be used to join rule keyword and rule value pairs together in the same rule (a logical AND). During a custom JumpStart installation, a system must match every pair in the rule before the rule matches. |
Is a name of an optional Bourne shell script that can be executed before the installation begins. If no begin script exists, you must enter a minus sign (-) in this field. All begin scripts must reside in the JumpStart directory. See "Creating Begin Scripts" for detailed information on how to create begin scripts. |
Is a name of a text file that defines how the Solaris software will be installed on the system when a system matches the rule. The information in a profile consists of profile keywords and their corresponding profile values. All profiles must reside in the JumpStart directory. Note - There are optional ways to use the profile field, which are described in "Using a Site-Specific Installation Program" and "Creating Derived Profiles With Begin Scripts". |
Is the name of an optional Bourne shell script that can be executed after the installation completes. If no finish script exists, you must enter a minus sign (-) in this field. All finish scripts must reside in the JumpStart directory. See "Creating Finish Scripts" for detailed information on how to create finish scripts. |
Save the rules file into the JumpStart directory.
The rules file should be owned by root and have permissions equal to 644.
This completes the procedure to create a rules file. To create profiles, go to "Creating a Profile".
