The following example tests the basic_prof profile against the disk configuration on a Solaris 7 system where pfinstall is being run. The basic_prof profile is located in the /jumpstart directory and the path to the Solaris CD image is specified because Volume Management is being used.
# cd /jumpstart # /usr/sbin/install.d/pfinstall -D -c /cdrom/cdrom0/s0 basic_prof |
The following example tests the basic_prof profile against the 535_test disk configuration file and 64 Mbytes of system memory. This example uses a Solaris CD image located in the /export/install directory, and pfinstall is being run on a Solaris 7 system.
# SYS_MEMSIZE=64 # export SYS_MEMSIZE # /usr/sbin/install.d/pfinstall -d 535_test -c /export/install basic_prof |
