Solaris Advanced Installation Guide
What Is the rules File?
The rules file is a text file that should contain a rule for each group of systems (or single systems) that you want to automatically install. Each rule distinguishes a group of systems based on one or more system attributes, and it links each group to a profile, which is a text file that defines how the Solaris software will be installed on each system in the group. For example, the rule
karch sun4c - basic_prof -
specifies that the Solaris installation program will automatically install any system with the sun4c platform group based on the information in the basic_prof profile. The rules file is used to create the rules.ok file, which is required for custom JumpStart installations.
Note -
If you set up the JumpStart directory by using the procedures on "Creating a Profile Diskette " or "Creating a Profile Server", an example rules file should already be in the JumpStart directory; the example rules file contains documentation and some example rules. If you use the example rules file, make sure you comment out the example rules that you will not use.
