Table 8-2 describes the rule keywords and rule values that you can use in the rules file.
Table 8-2 Rule Keyword and Rule Value Descriptions|
Rule Keyword |
Rule Values |
Description |
minus sign (-) |
Match always succeeds. |
processor_type Valid values for processor_typeare sparc for the SPARC platform, and i386 for the x86 platform. |
Matches a system's processor type. The uname -p command reports the system's processor type. |
domain_name |
Matches a system's domain name, which controls how a name service determines information. If you have a system already installed, the domainname command reports the system's domain name. |
disk_name size_range disk_name - A disk name in the form cxtydz, such as c0t3d0, or the special word rootdisk. If rootdisk is used, the disk to be matched is determined in the following order:
size_range - The size of the disk, which must be specified as a range of Mbytes (xx-xx). |
Matches a system's disk (in Mbytes). Example:
The example tries to match a system with a c0t3d0 disk that is between 250 and 300 Mbytes. Note - When calculating size_range, remember that a Mbyte equals 1,048,576 bytes. A disk may be advertised as a "535 Mbyte" disk, but it may have only 510 million bytes of disk space. The Solaris installation program will actually view the "535 Mbyte" disk as a 510 Mbyte disk because 535,000,000 / 1,048,576 = 510. So, a "535 Mbyte" disk would not match a size_range equal to 530-550. |
IP_address |
Matches a system's IP address. |
host_name |
Matches a system's host name. If you have a system already installed, the uname -n command reports the system's host name. |
slice version slice - A disk slice name in the form cwtxdysz, such as c0t3d0s5, or the special words any or rootdisk. If any is used, all of the system's disks will try to be matched (in kernel probe order). If rootdisk is used, the disk to be matched is determined in the following order:
version - A version name, Solaris_2.x, or the special words any or upgrade. If any is used, any Solaris or SunOS release is matched. If upgrade is used, any upgradable Solaris 2.1 or greater release is matched. If the installation program finds a Solaris release but is unable to determine the version, the version returned is SystemV. |
Matches a disk that has a root file system corresponding to a particular version of Solaris software. Example:
The example tries to match a system that has a Solaris 2.5 root files system on c0t3d0s1. |
platform_group Valid values are: sun4d, sun4c, sun4m, sun4u, i86pc, prep. (See Appendix C, Platform Names and Groups for a detailed list of systems and their corresponding platform group.) |
Matches a system's platform group. If you have a system already installed, the arch -k command or the uname -m command reports the system's platform group. |
physical_mem The value must be a range of Mbytes (xx-xx) or a single Mbyte value. |
Matches a system's physical memory size (in Mbytes). Example:
The example tries to match a system with a physical memory size between 16 and 32 Mbytes. If you have a system already installed, the output of the prtconf command (line 2) reports the system's physical memory size. |
platform_name |
Matches a system's platform name. See Appendix C, Platform Names and Groups for a list of valid platform names. To find the platform name of an installed system, use the uname -i command or the output of the prtconf command (line 5). Note - If the platform_name contains spaces, you must replace spaces with underscores (_). For example: SUNW,Sun_4_50 |
network_num |
Matches a system's network number, which the Solaris installation program determines by performing a logical AND between the system's IP address and the subnet mask. Example:
The example tries to match a system with a 193.144.2.8 IP address (if the subnet mask were 255.255.255.0). |
Solaris_2.x |
Matches a version of Solaris software already installed on a system. Example:
The example tries to match a system with Solaris 2.5 already installed. |
size_range The value must be specified as a range of Mbytes (xx-xx). |
Matches the total disk space on a system (in Mbytes). The total disk space includes all the operational disks attached to a system. Example:
The example tries to match a system with a total disk space between 300 and 500 Mbytes. Note - When calculating size_range, remember that a Mbyte equals 1,048,576 bytes. A disk may be advertised as a "535 Mbyte" disk, but it may have only 510 million bytes of disk space. The Solaris installation program will actually view the "535 Mbyte" disk as a 510 Mbyte disk because 535,000,000 / 1,048,576 = 510. So, a "535 Mbyte" disk would not match a size_range equal to 530-550. |
