No upgradeable disks
Problem
How to Fix the Problem
Bug ID: 1191792
A swap entry in the /etc/vfstab file is causing the upgrade to fail.
Comment out the following lines in the /etc/vfstab file:
All swap files and slices on disks not being upgraded
Swap files that are no longer present
Any unused swap slices
